Throttle body cleaning issues EPIC Volvo saga...RESOLVED!!
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
A cheapy throttle body sold in the USA: http://www.ebay.com.au/itm/230932295891 ... 1423.l2649
Rocky
Year and Model: 2003 xc70
Post by Rocky »
precopster wrote:A cheapy throttle body sold in the USA: http://www.ebay.com.au/itm/230932295891 ... 1423.l2649
Love the way they say it fits but may require dealer programming.
precopster
True though FCP say that about their OEM Bosch ones as well and they should know better
sergio
Year and Model: S60 2002
Post by sergio »
precopster wrote:
Rocky wrote: Love the way they say it fits but may require dealer programming.
Very interesting, they all say "may require dealer programming" :lol:
Wonder if they know what they are selling :lol:
S60 2002 180K miles looks and runs like new (except when sulking)
sergio
Post by sergio »
Had replaced MAF now replaced Throttle Body. The result is; there is no change :(
The engine started with several big bangs (backfire etc) then went rumbling (oscillating RPM) again.
I let it run for few minutes then it stopped.
I'm attaching 2 printouts.
What am I doing wrong?
1.pdf
printout of Dice Vida
(17.2 KiB) Downloaded 449 times
2.pdf
(17.02 KiB) Downloaded 242 times
precopster
Adapatation process. Was it done according to the PDF I attached?
One of the attachments has me confused. It says 99% turbo pressure and 2.7% desired throttle angle. Is the car at idle during this table?
sergio
Post by sergio »
Yes,and it has been on idle since the day I put things back after cleaning my old TB and the PCV. A month ago.
precopster
jimmy57 where are you?
When you look at the throttle adapatation in ECM module does it still say that throttle is not adapted?
sergio
Post by sergio »
These are the printout of the reading I get.
You told me that to activate a Bosch (non Magnetti) unit all I had to dowas to clear the code, start the engine, let run for a few minutes then it will set itself.
The codes don't clear. I mean they come back right after they are cleared!
xmlDocPrintPreview.pdf
adaptation
(33.91 KiB) Downloaded 176 times
activation.pdf
activation
(19.81 KiB) Downloaded 200 times
5.pdf
after I press next /ok
(9.04 KiB) Downloaded 201 times
precopster
Hi Sergio. You really are having a rough time with this aren't you?
These docs don't show the state of throttle adaptation. The area is in Vehicle Communication and then click Parameters Tab then then the ECM module icon then plus sign to find Adaption Throttle Unit. Double click it. It will then show you the state of the adaptation.
What does yours say Sergio?
