ETM software
precopster
- Year and Model: Lots
- Been thanked: 128 times
Re: ETM software
Actually Vida is the ONLY Volvo factory software that helps to read anything post 1998 so anything 1999 and over.
- Has thanked: 1497 times
- Been thanked: 3810 times
That sounds like limp mode , Tim, usually caused by bad ETM
precopster
precopster
Start and restart engine at least 3 times with a run of more than 5 minutes with no clearing of codes by a scanner. You should get at least an ETS light or the engine light.
Are you familiar with an ELM 327 device? You can read engine codes with a laptop or a Android or I Phone using this OBDII adapter.
Tim..I can whip by with my AUTEL and see if any ECMs are pending ...where are you in CT? Driving through Tuesday
meghalpatel
- Year and Model: 1999 S70
Hello i have volvo s70 1999
have ETM with white tag hasn't been replaced from original.o since couple of months i am having "limp home" mode situation car runs at 20-30 miles and after 6-7 miles i restart it runs normal,this has been situation from couple months but now after u got fed up,ordered online an ETM with yellow tag replaced it gives god throttle response. But there is a big problem at start up idle surges very high and remains at that high(2000 rpm) point fluctuating there. So i guess this ETM that i ordered online didn't mate with my car.So can this be solved by updating software or for this high idle there is some other problem??
Please help i am stuck with no ride now. Also have all kind of fault lights coming on the dashboard like Check engine,brake-ABS, flashing arrow,ETS etc. but these lights come and go.they are not steady forever.Also they have no effect with this throttle body problem. Thats what i understood till now.
Please give me some insight on above problem on how to solve it.
Thanks
Thanks
- 1547 Views
Last post by the65dartguy1
- 1771 Views
Last post by Tim
