Please Help with this Popping Noise
zakmuh
- Year and Model: 2003 XC90 D5
- Has thanked: 6 times
SOLVED
I replaced the injector with a used eBay one and it sorted the issue out, no more misfiring.
I wanted to re-calibrate my one, so I rang up a local injector specialist. They advised me to buy a refurbished one as it cost the same to re calibrate as it involves replacing internal parts and quoted £150 + VAT. The technician also said that my XC90 does not require coding/programming BUT Bosch's part number 0445110251 should match number to number. So it's like just replace and drive. Volvo's part number (30750283) irrelevant.
Taking his 'Bosch part number' advice, I searched on eBay and luckily a local breaker had the same one. I cleared the code and it's running as before now. I thought I'd update you as this might help someone in the future
Cheers
Cheers
- 11 Replies
- 3623 Views
Last post by hunterhuni
- 1456 Views
Last post by oragex
- 1588 Views
Last post by chris11211
- 572 Views
Last post by GlennG2759
- 2706 Views
Last post by SuperHerman
