454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 130 times
Post by 454cid »
Yesterday, I got my Bluetooth OBD2 adapter and downloaded the 850 OBD2 app, and found out how many miles my car has on it. I bought it thinking it was 76K miles, but after buying it, it was apparent the odometer didn't work. It actually has 88K miles on it, and I've probably put 1000 of that on it myself. 11K miles higher than I expected isn't too bad. I was afraid it was going to be a huge amount. The thing that kept me hoping it was still a low miles car is that it seems to be quite original.... Timing components (and water pump) seemed to be original and in good shape, for instance.
My next "project" aside from the wipers and door lock pins/knobs I've started threads about, will be to check the gas mileage, now that I can keep track of the miles driven.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
454cid
Post by 454cid »
abscate wrote: 02 Feb 2022, 19:51 Beautiful sunny 40F day so I sorted out most of the brakes and exhaust on the S70 AWD
What was the issue with the exhaust?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Has thanked: 1505 times
Been thanked: 3818 times
454cid wrote: 02 Feb 2022, 20:45
It’s a Resurrection car, we had to drop the entire back axle to service rusted fuel lines on this AWD
There is a “ Resurrection of Ekaterina” thread in this forum
FireFox31
Has thanked: 158 times
Been thanked: 300 times
Post by FireFox31 »
454cid wrote: 02 Feb 2022, 20:44 I bought it thinking it was 76K miles, but after buying it, it was apparent the odometer didn't work. It actually has 88K miles on it, and I've probably put 1000 of that on it myself. 11K miles higher than I expected isn't too bad.
Is there any way to advance the odometer to show the correct mileage?
I was at a Volvo dealership years ago and overheard a customer talking to the service advisor about his 850 broken odometer. The advisor told him he'd have to get a new odometer with mileage reset to zero. The customer seemed shaken, quite proud of his high mileage. To this day, I kick myself for not interjecting and saying that the odometer gear could be repaired and he could keep his mileage. Would you keep quiet or share the information?
FireFox31
454cid
Post by 454cid »
abscate wrote: 03 Feb 2022, 01:25
Wow, that sounds like a lot of work!
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
454cid
Post by 454cid »
FireFox31 wrote: 03 Feb 2022, 01:59
Yes, it can be advanced, but I'm not clear exactly how it's done. Robert has a Youtube video on it, but it still wasn't clear to me, even after watching it. I assume it's one of those things that's a bit hard to explain to someone that doesn't have their hands on it.
I will figure it out when I change that gear. I won't try it until better weather.
Either the service advisor would argue back or simply state that replacement was the extent that the dealer could provide, would be my guess. Many years ago (early 1983, I think) my grandmother bought a new Dodge that needed the odometer replaced, and I think it was installed at zero when the car had a few thousand miles on it.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
ZionXIX
Has thanked: 65 times
Been thanked: 194 times
Post by ZionXIX »
I've done it. It's a pain but doable. Robert's first method involves advancing the smaller counter with a drill attached to something with a little friction such as a broken or short pencil with the eraser making contact with the small plastic gears. I tried using a dremel tool with small barrel sander attachment and no actual sanding material attached. Just the rubber holder. This worked well since I could adjust the speed. I abandoned this method because I got impatient and wanted to see how fast I could make the gears go. I broke one of the plastic teeth. The second method involved using a "punch" to push the pin holding all of the odometer numbers and gears in place. It's easy to misalign them but honestly it was much faster than the first method. You can simply change to the number you need to correct the mileage. I had to add like 80,000 to my odometer.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2655 times
Been thanked: 1248 times
Post by matthew1 »
Also -> Amazon link
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
FireFox31 wrote: 03 Feb 2022, 02:01 Nice pictures. Where is the o-ring? Sveedy, do you have a picture of the back of the coolant pump with the coolant pipe removed? From your description, I can't picture how it works.
I have a spare block I take take a pic of. It's just a smooth surface IIRC, press fit with the coolant pipe.
yanga001
Has thanked: 59 times
Been thanked: 110 times
Post by yanga001 »
BlackBart wrote: 02 Feb 2022, 12:37
yanga001 wrote: 01 Feb 2022, 13:09 Bit the bullet and spent 300 for new iridium plugs....
Dollars?? Or did you mean $30?
300$ unfortunately. Realized I paid a bit of a premium for the volvo dealership rotor and crappy tire plugs. Rock auto will be in the future for the plugs as they were 7$ per as opposed to 11$ :(.
the distributor cap was cheaper at the dealer however the rotor was about 30$ more so 41$ pissed away. Happy thats about an hours work as opposed to 3 now.
This Saturday will be a bit of a do or die as im not sure if i have a blown head gasket. will make a separate thread
2008 S60 2.5T Auto (Sold)
