- Has thanked: 317 times
- Been thanked: 531 times
My key fob that I had with my '98 barely worked, but when it did, it would flash upon locking only. Not unlocking. I'm not sure if the 850 acts the same, as it uses a different fob and possibly the whole system.
- Fiodor
- Year and Model: 1997 V70 2.0 T5 AWD
- Has thanked: 13 times
- Been thanked: 9 times
Yup exactly !454cid wrote: 12 Mar 2022, 11:28Do you mean locking and unlocking with the key fob? Mine doesn't give any indication I've locked it, and I wish it would. I have to look at the lock buttons, or listen and sometimes I'm too far away to see, and my fob is not reliable for some reason..... I guess I need to disassemble it and maybe clean the contacts.Fiodor wrote: 11 Mar 2022, 10:54 A miracle happened today!
I didn't know the blinkers were supposed to flash when you open and close the car because mine never did that.
After leaving my car for 6 months and draining the battery it suddenly started working again.
Any explanations?
1997 V70 T5 2.0 AWD with welded angle gear at 240k km
1990 740 Break (dead)
- Has thanked: 1611 times
- Been thanked: 4075 times
Whose famous, over 90, and still drives a stick shift??
Queen Elizabeth II
MY Mom
Queen Elizabeth II
MY Mom
Keep the boxes coming and the cars rolling ….
- BlackBart
- Has thanked: 967 times
- Been thanked: 923 times
No way! Fantastic!abscate wrote: 13 Mar 2022, 06:30 Who’s famous, over 90, and still drives a stick shift??
Queen Elizabeth II
MY Mom
- BlackBart
You might try getting it good and hot, parking in a clean place, and watch for drips.FireFox31 wrote: 11 Mar 2022, 10:22My coolant level is gradually dropping and I'd like to know where it's going.
Alternatively, it could be leaking and burning off on a hot part of the engine. Is there any burned coolant smell?
Also look around for dried white coolant spray/leakage.BlackBart wrote: 13 Mar 2022, 08:46You might try getting it good and hot, parking in a clean place, and watch for drips.FireFox31 wrote: 11 Mar 2022, 10:22My coolant level is gradually dropping and I'd like to know where it's going.
- BlackBart
Right, like around any hoses and fittings, or down the radiator seams.
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
Finally properly mounted my front license plate. swapped the zip ties for the nuts as needed and it looks secure.
2008 S60 2.5T Auto (Sold)
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
My radiator would only leak when hot. It was leaking around the plastic/aluminum crimp. It took a while to find that one. My clue was the lack of pressure in the system.
