Has thanked: 1613 times
Been thanked: 4078 times
Is that in the gorgeous Coral Red?
Perfo wheels rock, too
I rolled the T5 to the airport for a 0615
Runs great on highway at 27 mpg at 55mph, but still has that little skip at float/ idle
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
Going together slightly easier than coming apart...
Fortunately between harvesting the bones of poor Old Blue, a few things from the stash acquired from a hoarder 2 years ago, and parts on the shelf bought back in Nearly Normal times, I haven't had to buy anything more brutal than brake fluid so far.
Several body parts are in distress now, though - mine, not the car.
yanga001
Has thanked: 62 times
Been thanked: 115 times
Post by yanga001 »
Recharged the AC on the workhorse today. Had a bit of a scare since it would not engage but cleared codes and it filled properly. A high pressure cutout warning sometimes goes off while filling and it will stop the compressor from further operation. My theory is that while filling there are spikes due to the compressor turning on and off. Clearing the code and filling lead to icy cold air coming through my vents. Picked up the fuel filter today, will swap it out later this week. The other appears to be original to the car.
2008 S60 2.5T Auto (Sold)
FireFox31
Has thanked: 159 times
Been thanked: 303 times
Post by FireFox31 »
Spiked60 wrote: 10 Apr 2022, 11:12 Been reading MVS for a long time but apparently have never posted
Welcome to the forum. Thats a lovely red and, as abscate said, the Perfo wheels look sharp.
car-part.com is a great resource. Hopefully you find a salvage yard with some combination of accurate inventory, helpful staff, safe conditions, and fair prices. When at the yard, remember to pick the obscure, no longer available parts which others might miss.
FireFox31
jmorman
Year and Model: 2000 s70 GLT SE
Post by jmorman »
Took three days but got the rack replaced and working on my 2000 s70 GLT se. Replaced the O2 sensors and that pesky engine mount just above the rack. It was soaked in PS fluid and the rubber was weird. She flipped 276,000 on the test drive :)
Documenting the SAS bung as 18mm x 1.5 thread pitch standard ( not pipe thread)
Also found my loose seat heaters, easily swapped from foam to foam seat.
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
abscate wrote: 15 Apr 2022, 20:58 Documenting the SAS bung as 18mm x 1.5 thread pitch standard ( not pipe thread)
Thanks for checking that. If you happened to have the pipe in hand, what kind of fitting screwed into the exhaust manifold? I'm trying to thing, what would be the proper way to seal it up, as a straight thread would not do that job by itself. Some sort of tapered seat?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
Use an 18 mm x 1.5 oil drain plug with copper face gasket?
Something like this.
https://www.amazon.com/SMART-Drain-Plug ... B00OZ6RZBW
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
I don't remember what I used on my '98, but I tried several drain plugs and they didn't work. I ended up getting a larger bolt from the hardware store and chopping it down some to be able to fit. Wish I could remember the thread size.
