yanga001
Has thanked: 62 times
Been thanked: 115 times
Post by yanga001 »
abscate wrote: 10 May 2022, 17:08
yanga001 wrote: 10 May 2022, 16:24 Took a look under the car, my passenger trailing arm severed at the ball joint. Could not identify yet where the leak is in the brake lines. It looks to be somewhere under the front drivers side so i cleaned the reservoir and booster with a cloth. Hoping to see if the puddle will guide me.
It probably yanked the brake line backwards and sheared it off under the car
The trailing arm is still there, just the ball joint at the end of it that connects to the section that goes across the car was severed.
Gonna pull codes with VOLFCR and see what happens in a little bit.
2008 S60 2.5T Auto (Sold)
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
Very stylish! Speaking of which, has anybody seen the Maddox branded Oetiker clamp assortment at Harbor Freight? I just noticed them in stock today. Nice set of smaller ones for $10.
Has thanked: 1613 times
Been thanked: 4075 times
Went out early am to run Ekaterina “ The Kat” S70 AWD as she isn’t registered. 1999 of course
She showed 28 mpg on the mpg counter over 10 miles, temperature took a long time to reach 3 o’clock, swishy shell speed noise on right. Nice and smooth acceleration and good power
Has thanked: 2212 times
Been thanked: 1853 times
Got a list of issues on my young friends V70 NA base to deal with and not a lot of time to do it.
Was dreading the door limit spring. Interestingly the one I fitted to the car had the LH/RH on it, but I have another that just has RH on it. I'm thinking that may be an aftermarket part. Need to see if it stamped with Volvo on it. Why I was not sure if they were interchangeable side-to-side was the large spring you are talking about is off-set to top or bottom (can't recall).
Fortunately, the door limit strap turned out to be loose on the T40 torx screw at the 'A' pillar. Don't know why it worked loose as it still had thread lock on it, so removed it and used new thread lock and hopefully that is it! Phew!
Also fitted the new Volvo MAF the owner had bought swapping out the used one that I got from PnP. That has been running good for the last month so I now have a known good working spare and 2 untried but clean units in vacuum sealed bags with desiccant. These are no longer available new except from Volvo at $350-450 CDN at the on-line Volvo dealers in Canada. I pulled 3 from PnP a few weeks ago and the car had been running happily on that one since. At least I have a good known running one in my stash now as well as 2 other cleaned but untested ones. They are stored in vacuum sealed bags with desiccant sacks in with them. Naturally they don't fit the 'R'. It's is larger diameter and different part number.
Swapped the master door switch for a used one from the stash as the aftermarket part in the car had gone wonky.
Hardest job is the on-going saga of the P0442 - minor emissions leak. Noticed last time I saw the car that the fuel filler neck had several dings in it as well as an aftermarket fuel cap.
When I looked closer it looks like somehow one side had been slightly flattened which would prevent an even seal. The aftermarket filler cap also has a narrower and shallower seal rubber. As I had a new Volvo cap in the stash I have fitted that and lightly sanded the filler neck contact area. Finally used some vaseline on the seal to take up any other small indents. Now need to wait about a week to see if it throws a code. Weird thing was the check light was on until she arrived but was off when I went to remove it with the code reader??
Hopefully we have a code free car in a couple of weeks when she brings it back to leave it with me for a couple of days to swap the winter tires over and do a suspension inspection while I am in there.
Officially completed the T5 resurrection with two new front tires and a front wheel alignment. Running Cooper CS5 from my local tire guy, 205 55 16
Nice, glad the T5 is fully operational again!
Neil
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
BlackBart wrote: 10 May 2022, 17:03 So Abscate, there's a gold, silver, diamond.....which year is the Oetiker anniversary?
1st anniversary.. paper
2nd anniversary.. cotton
40th anniversary.... Oetiker clamps !!! He got a keeper!! :lol: :lol:
04s60 2.4
04xc70 2.5t
yanga001
Post by yanga001 »
Heading to my indy on Tuesday to get a pulse on the car. It drives well and did 160 km with no sweat but i do not want things to pile up here. I am seeing some suspension work in the future but i am more worried about the brakes as it showed low fluid which gives me about 2-3 days for a brake tank fillup.
Pounded the T5 for a cross state trip. Made ALB to ROC back to ALB, picked up ShepHusky, made 8 pm ferry!
About 600 miles total, 25.5mpg. Some boost was used
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
abscate wrote: 14 May 2022, 02:05 Some boost was used
LOL, one of these days maybe I'll own a turbo. I haven't even really been using vacuum lately. I've gotten my truck back on the road, and have been procrastinating on changing the O2 sensor on the Volvo.... I really need to get that done today.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
