yanga001
- Has thanked: 62 times
- Been thanked: 115 times
Replaced the brake switch which stopped the leak. At the same time, one of the motor mounts when out causing a clack clack clack sound periodically. Checked and i dont have an engine peephole nor does it always occur so i dont think its knock. Dont know if i want the pleasure of replacing the mounts or to let me indy do it when he does the axel.
2008 S60 2.5T Auto (Sold)
- Has thanked: 2215 times
- Been thanked: 1853 times
If you are doing the axle soon then you can leave it to the mechanic, assuming the mount is the crank pulley one as the axle is already bad. If it is the passenger side one and the RH axle is good then do it ASAP as it will damage that one!
There is a flap on the RHS, but you have to pull the RHF wheel and undo a small 15mm plastic nut and then the inner fender folds back so you can see the mount.
yanga001
scot850 wrote: 22 May 2022, 11:48 If you are doing the axle soon then you can leave it to the mechanic, assuming the mount is the crank pulley one as the axle is already bad. If it is the passenger side one and the RH axle is good then do it ASAP as it will damage that one!
The right hand axel is bad. My mechanic has a bunch of the centre cushion mounts spare and i can ask him to order the one under the pulleys to replace that one as well. I heard its best to hit as many of the mounts as once as they all tend to wear fairly evenly. I can pull a spare transmission mount from my crashed car on monday.
The sound is not as bad today leading me to think it was due to the high temperatures causing the rubber to expand or contract. There is noticeably more engine vibrations recently.
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
Cleaned my rims, and then tried cleaning the remainder of the bad 02 soot from the rear of the car. Neither came completely clean.
The wheels obviously need more work. I used Chemical Guys Diablo Spray wheel cleaner....expensive stuff. It did not get everything, even with two applications scrubbed with a dollar store brush. Any recommendations?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
^ Oven cleaner ? I haven't tried it yet, but I've heard of it being used for wheels.
1999 V70 GLT
1999 V70 GLT
- Has thanked: 317 times
- Been thanked: 531 times
Lemme guess, heavy deposits? Try some scotch brite pads. I usually get them at Home Depot, they have a couple different types. A more mild one will be easier on the finish and avoid deep scratches.
454cid
I don't recall which rims I have, but maybe I should have mentioned they're painted? Scotchbrite would surely scratch the finish. I was leery of using the scrub sponge as it had a Scotchbrite-like side to it, but doesn't have the grit that Scotchbrite has.bmdubya1198 wrote: 22 May 2022, 19:51 Lemme guess, heavy deposits? Try some scotch brite pads. I usually get them at Home Depot, they have a couple different types. A more mild one will be easier on the finish and avoid deep scratches.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
454cid
Maybe I'll try it on the backside of one of the rims. It might etch the paint.Sveedy wrote: 22 May 2022, 18:57 ^ Oven cleaner ? I haven't tried it yet, but I've heard of it being used for wheels.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Ah yeah, that could be a problem for the paint.454cid wrote: 22 May 2022, 20:26I don't recall which rims I have, but maybe I should have mentioned they're painted? Scotchbrite would surely scratch the finish. I was leery of using the scrub sponge as it had a Scotchbrite-like side to it, but doesn't have the grit that Scotchbrite has.bmdubya1198 wrote: 22 May 2022, 19:51 Lemme guess, heavy deposits? Try some scotch brite pads. I usually get them at Home Depot, they have a couple different types. A more mild one will be easier on the finish and avoid deep scratches.
- Has thanked: 1613 times
- Been thanked: 4078 times
It will certainly etch anything with Aluminum in it , so without knowing your wheel alloy, I would proceed with caution.
