Has thanked: 2210 times
Been thanked: 1852 times
I hope so as I have been doing this with P80's for 25 years! :lol:
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
FireFox31 wrote: 28 May 2022, 10:05 When I lift my car using a four-post automotive lift, I put the front pads on this subframe mount. Specifically, I put the pad touching the back two bolts and the center bulge. Is that a safe way to lift the car?
It is, just avoid the edge where mine is bent lol. It’s a structural part of the car, so it’s a good solid lift point.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
That's exactly where I always put my jack stands. Much better than the plastic bumper.... :)
1999 V70 GLT
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
Sveedy wrote: 27 May 2022, 15:09 Also got away from this problem....
I like modifications where you go to similar models and get alternate parts.
Sveedy wrote: 28 May 2022, 11:12 That's exactly where I always put my jack stands. Much better than the plastic bumper.... :)
Seconded, this is where I lift with a wood block on top of the jack stand.
For safety reasons I try to avoid using blocks of wood between the jack stand and anything I am lifting. Although I am careful I have had instances of the wood breaking and slipping. Only time I use a piece of 1/2" is when carefully jacking the oil pan to check or replace the crank pulley motor mount.
I have thick rubber pads bought at Princess Auto up here that swap in place of my regular floor jack metal castellated lift pad.
These are just drop in items.
While I appreciate it is not what everyone can afford to do, I just bought a higher lift capability floor jack to lift my 4Runner as the regular 3 ton floor jack could not lift the car high enough to remove the wheels without using a piece of wood. I would have sold my old one but the new one is too big to go under the 'R'.
Please also always use jack stands under the car and do not rely on the floor jack to support your car.
Volvebaker
Year and Model: 1993 850 GLT
Been thanked: 12 times
Post by Volvebaker »
Replaced the ball joints and tie rod ends. Boy, what a world of difference!!
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
Volvebaker wrote: 28 May 2022, 13:25 Replaced the ball joints and tie rod ends. Boy, what a world of difference!!
I thought the ball joints were part of the control arms on these cars?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
454cid
Post by 454cid »
I cleaned my rims again. Trying to get the buildup off. Last week I used Chemical Guys Diablo, which I've since read is better for maintenance cleaning of rims. This week I tried a Black Magic product and a Mother's foaming wheel cleaner. I used the Black Magic cleaner on all four of the rims, and on 3 it seemed to leave a bit if white haze, but did get more gunk off. I then did the front rims again, one with the Diablo, and one with the Mother's. They are getting better... which unfortunately, shows they're kinda beat up.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Volvebaker
454cid wrote: 28 May 2022, 17:40
I’ve got one of the earlier runs of the cars, which had removable ball joints. A ‘93. Considered by some to be a handicap to own, considered by me, an advantage. Minor differences all around but I honestly prefer most to the latter inceptions. But I love ‘em all :P
