Well I'm a little confused in what situation what codes I had but....precopster wrote:Can you tell me the Vida codes you saw when this happened to you? Then I'll know what to spot, of course better to just do the vertical cut, match the voltages and be done with it.
1. First shot. A unit with voltages out of range (errrr 0.2V lower than original):
ECM-903F Throttke position (TP) - Signal too low
ECM-9150 Throttke position (TP) - Sensor 1 - Faulty signal
ECM-9160 Throttke position (TP) - Sensor 2 - Faulty signal
ECM-91B7 Throttke position (TP) - Faulty position
2. Secound Shot - killed/shorted ETM.
ECM-903F Throttke position (TP) - Signal missing
ECM-9190 Throttke position (TP) - Faulty current
ECM-91A7 Throttke position (TP) - Faulty control
3. Third shot - well it seems I didn't make a screenshot - sorry. By memory the codes was similar as with the kiiled by me ETM. i got screenshot only of the Graphic display with checked TPS1; TPS2 and Accelerator pedal position (masured value, not the electronic).
p.s. Today i got MIL on DIM but I'm too lazy to go down to the car to check it out. I guess I know why.... I'm on LPG aftermarket fit, and the gasoline injectors are becoming clogged little by little. When starting the car it starts on gasoline, wait to warm till 50 deg C and then switch to LPG. This morning the engine was working bad while heating, so i guess i got Missfire 5-th or 6-th cylinder stored. However, i belive the MIL is not because of the ETM ... or at least I hope so
