How to read your actual miles from the ECU
How to Read Actual Miles from the ECU
ERO1
- Year and Model: 1996 850GLT ; 2007 X
- Been thanked: 2 times
No, on the 96 you have to retrieve the mileage from the OBD II. It takes a special scan tool. I was lucky in that the Charlottesville, VA dealership knew exactly what I was talking about and was able to do it very cheaply. Some where in this thread is all my posts about my issues in retrieving the mileage on my '96 850. Here it is...hope this helps! https://www.matthewsvolvosite.com/forums ... 23#p212484
White 1996 850GLT first Volvo.... loving it!
Magic Blue 2007 XC90
I have a '96 850, so I can't get the tru mileage but I am going to just add what I figure we put on it in a year. What I need to know is how can I add the mileage to the odometer?? I don't want to screw it up , but would really like for it to read close to what it has, so I can change the timing belt when it comes due. Thanks
esl_97_850_T5
- Has thanked: 18 times
- Been thanked: 27 times
Foxxy,
If you really want to know your '96 850 mileage, you can do so as a relatively easy, low cost DIY project.
As marshappynation mentioned at /viewtopic.php?f=1&t=56686#p299637 and thrich mentioned at /viewtopic.php?f=1&t=58722, you can read the 1996 850 mileage with an ELM327 cable and a terminal emulator like Hyperterminal or Realterm, avoiding the trip to the dealer, at least for that "mileage reading" purpose.
You can follow the To Read Vehicle Mileage instructions at /viewtopic.php?f=1&t=58822#p298996 to retrieve the raw data for the '96-'97 850 mileage. Then use one of the two methods listed there to convert the raw mileage into something meaningful.
Or you could use the 2 posts by marshappynation and thrich and follow their provided links and/or references.
Any of those approaches should help you to read your '96 850 mileage yourself.
[But if you do use the dealer to read the mileage, then be sure to go equipped with the instructions that were included in jimmy57's Volvo Scan Tool instructions to retrieve the correct mileage on 1996 850, in case the dealer says they don't know how to read the mileage in a '96-'97 850.]
esl_97_850_T5
esl_97_850_T5
1998 Volvo S70 GLT - 205.5K miles - S70 & M44 testbed in 2016-2019; traded 2019-07-15 (for spare time)
1997 Volvo 854 T5 - 147K miles - 850 testbed in 2012-2017; junked 2017-09
- 3129 Views
Last post by Rucho26
- 1991 Views
Last post by coflynn
- 23 Replies
- 3961 Views
- 1682 Views
Last post by 850_GLT_Owner
- 3997 Views
Last post by jonesg
