What non automotive projects and repairs are you doing?
Forum rules
Has thanked: 1611 times
Been thanked: 4072 times
volvolugnut wrote: 13 May 2021, 08:37 I had to google grace ice shield. It is not a big issue in the warm and dry south (usually). When my last roof was installed, I used architectural shingles. They are heavier and the insurance rate was lower. The insurance reduction nearly paid for the additional shingle cost. The issue we have here is hailstorms. We can expect to replace a roof every 10 to 15 years because of single or multiple hail storms.
After a heavy snow, we get ice dams. The snow melts at the roof, refreezes, which creates a blockage for water , usually at the edge of the roof. It then backs up under the shingles and into the house
Not a problem for an event, but if it happens every year, the wood will rot. The grace shield stops the water from coming in
The alternative is to roof rake your snow off , which amuses me because most only rake the edge.
Duh.
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
Upgrading a circuit to 20AMP in main panel, task includes safety checks, EMT bending and offsets, 12/2 conductors, boxes, GFCI, outlets and switches. Life of a homeowner, Lol!
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
xHeart wrote: 22 May 2021, 06:46 Upgrading a circuit to 20AMP in main panel, task includes safety checks, EMT bending and offsets, 12/2 conductors, boxes, GFCI, outlets and switches. Life of a homeowner, Lol!
That is a detailed check list!
xHeart
Post by xHeart »
3 point saddle bend 3-60-30 worked without kink for a 2" riser - tighter space; added a separate switch controlled outlet for IOTA DLS55.
xHeart
Post by xHeart »
Does a 20A circuit flows faster than 15A?
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
xHeart wrote: 25 May 2021, 14:46 Does a 20A circuit flows faster than 15A?
Not faster they both flow at speed.
The 20A does flow more electrons in the same amount of time then the 15A.
1 Amp = 1 Coulomb of charge per second. ( A=C/s )
1 Coulomb ~ 6.24 × 10^18 electrons.
Active
Past
xHeart
Post by xHeart »
Is there a rule for how many circuit breakers in a 135A main panel?
RickHaleParker
xHeart wrote: 26 May 2021, 11:27 Is there a rule for how many circuit breakers in a 135A main panel?
The National Electrical Code (NEC) specified that a lighting and appliance branch circuit panelboard could not contain more than 42 overcurrent devices (circuit breakers). That was the absolute maximum, unless the manufacturer specified a lower number, which was often the case for smaller panel boxes.
Active
Past
GlennG2759
Year and Model: 2006 V70 NA
Has thanked: 112 times
Been thanked: 17 times
Post by GlennG2759 »
I’m gutting a room in my 1825 house that still
has plaster and lath in it. After 15 yrs. this the last room left. Always a freakin mess. Next rewire, insulate, sheetrock, tape/spackle, paint, refinish floor, trim, and a marguerita. My, have construction material prices have gone thru the roof !!
RickHaleParker wrote: 26 May 2021, 15:12
Uh, oh....1,2,3,4,5...whew, I’m ok....
