FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
W; look for '00 XC in case the R needs AWD parts!
Current Volvos:
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
The driveshaft was already removed from the R, and I probably won't fix it. Unless I come across a good deal on a 2000 XC to fix it, that may be a good idea if I don't go with an M56 to replace the dead AW55!
tonyd555
Year and Model: 2005 S40 T5 AWD
Has thanked: 3 times
Post by tonyd555 »
Finally all the parts for the 850R have arrived and today replaced the PCV, thermostat, ABS module and spark plugs. Started the brakes late last week and have 3 wheels left to do and will finish them tomorrow.
brunocerous
Year and Model: 1998 V70
Has thanked: 303 times
Been thanked: 43 times
Post by brunocerous »
Mostly watched my brother (thewifes_s70) swap out the struts in my '98 V70 over two days due to my late arrival and our dinner plans. (Happy graduation!)
The old ones weren't as bad as in the '00 V70: One almost rebounded on its own after being fully compressed. I neglected to order strut mount caps, so ended up using the OE ones that were on there.
1998 V70 struts
1998 V70 struts
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
Has thanked: 1614 times
Been thanked: 4078 times
Now I know where Im borrowing my strut compressor when needed... :-)
Question- What do you do when there oil all over the top of your engine and you can't find any leak?
Answer - tighten your loose oil filler cap.
bmdubya1198
Got a '99 T5M (C70) ETM today for the R. From what I understand, there is no difference between auto and manual ETMs. I plugged it in and it turned on like it should have. Didn't open and close with the gas pedal (I believe it's supposed to, but my current one doesn't either from what I can hear), but it turned on and off like it's supposed to. Will it work?
Both white label, and what's left of the part number (2 numbers, rest was rubbed off) it matches the current ETM.
abscate wrote: 03 May 2018, 07:55 Now I know where Im borrowing my strut compressor when needed... :-)
There are rookie mistakes and expert mistakes. Unfortunately we more experienced DIYers make these "expert mistakes" every now and again.
Bonus tip... if you have '99+ with a misfire on multiple cylinders, make sure your coil wires are plugged into the right coils. But you'd have to be an IDIOT to make THAT mistake... :?
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
Anytime my friend! P.S. Project Eurovan starts soon! :wink:
Retired:
2015 Volvo S60, T5, 85K
bmdubya1198 wrote: 03 May 2018, 14:24 Got a '99 T5M (C70) ETM today for the R. From what I understand, there is no difference between auto and manual ETMs. I plugged it in and it turned on like it should have. Didn't open and close with the gas pedal (I believe it's supposed to, but my current one doesn't either from what I can hear), but it turned on and off like it's supposed to. Will it work?
Your ETM candidate should pass the 8 second click whine test on power up, but it won’t move after that. Your 99 car is much too smart to bother with opening throttle while the engine isn’t running.
bmdubya1198
Good to know, because it clicks on just fine and makes that whine. Should be fine!
bmdubya1198 wrote: 04 May 2018, 07:48 Good to know, because it clicks on just fine and makes that whine. Should be fine!
Passing on a thank you from the serpentine belt thread, for that trick with the socket adapter as belt tensioner...
