When the radiator starts to leak/crack there, your first points to check are your upper and lower torque rod bushes but more importantly the crank pulley mount. When that one fails, the engine moves a lot more on that side and puts more strain on the top water hose area.
I would JB Weld it and check those mounts. Then plan for a replacement radiator when you can.
- Has thanked: 2210 times
- Has thanked: 316 times
- Been thanked: 531 times
Yeah, that radiator is about to burst. Definitely replace it ASAP.
- Goupil
- Year and Model: 98' V70 LPT
- Has thanked: 30 times
- Been thanked: 115 times
Finally got myself to put the carpet back in the V70 after the heater core leak in.... May I think
The insulation under the carpet was damaged so I had to patch it using some from the parts car C70
Also got the oil pressure gauge installed properly
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
duke1
- Year and Model: 855 1994 10v
- Has thanked: 416 times
- Been thanked: 34 times
fitted nice tidy new carpets as the original are stained from coolant,these are cheap from ebay but fit quite nice and look much nicer!
https://www.ebay.co.uk/itm/255637119640 ... 5571686739
they do many more volvos as well.
next mission is tackling the paintwork,,,yuck!
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
Very clean install on that gauge ! How did you install the sensor ?Goupil wrote: 20 Nov 2022, 12:12 Finally got myself to put the carpet back in the V70 after the heater core leak in.... May I think![]()
1999 V70 GLT
1999 V70 GLT
- Goupil
It's clean until you see the back of the gauge, I didnt want to remove the vent door so I had to bend/cut a few things
At least I felt like a pro when using a grommet for the wires
Credits to this guy on thingiverse for the grille
https://www.thingiverse.com/thing:4077096
I've used a VDO sensor that has the right thread to bolt straight in place of the stock sensor. It comes with a low pressure contact so I was able to keep the dashboard light working as factory
https://vdo-webshop.nl/en/pressure-send ... 90944.html
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
Swapped out a crusty downpipe on my wife's GLT and added an additional resonator to the system.
The current system (aside from the old 3" DP) was stainless. Just a fairly low-grade, evidently. The pipe cleaned up just fine for welding, and wasn't pitted at all.
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
Went to pick up the new license plate.... I'll get it screwed down shortly. I'm trying to decide how. I may buy new stainless nuts, or I may just coat the threads with either anti-seize, or lanolin spray.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 1611 times
- Been thanked: 4073 times
Pm me your address and I’ll send you set of the nice SS belmetric cone nuts just for being so cool.454cid wrote: 23 Nov 2022, 00:46 Went to pick up the new license plate.... I'll get it screwed down shortly. I'm trying to decide how. I may buy new stainless nuts, or I may just coat the threads with either anti-seize, or lanolin spray.
- Sveedy
So are you working with an IPD cat back ( I guess now turbo back ) or the stock system ? I've seen 4" x 12" aftermarket resonators and was thinking about adding one to my IPD system, but I've kind of gotten used to (ok I like it) it now.Chuck W wrote: 22 Nov 2022, 16:36 Swapped out a crusty downpipe on my wife's GLT and added an additional resonator to the system.
1999 V70 GLT
1999 V70 GLT
