lowest_std branch. Do "git pull" & "git checkout lowest_std" in your git clone, or, if no git, click on the branch button in github web ui and select the lowest_std branch.RickHaleParker wrote: 07 May 2021, 12:20I got the impression you pushed the change in Master. Is Master or Rework where you pushed the Lowest_std change?
Vida CEM swapping
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
- RickHaleParker
- Been thanked: 980 times
Found it. Will run it later.vtl wrote: 07 May 2021, 12:22 lowest_std branch. Do "git pull" & "git checkout lowest_std" in your git clone, or, if no git, click on the branch button in github web ui and select the lowest_std branch.
Playing with new toys right now.
Active
Past
Past
solitaire
- Year and Model: v40 2016
- Has thanked: 3 times
- Been thanked: 6 times
vtl for me OLD code is best
I found best sample is from 9 - 20 and first two bytes always correct and 3 bytes is in list from 1 to 5
can you add to OLD code:
if pin not found try
bruteforce again with first two and next candidate (3) from list
I think it will be great variant
- RickHaleParker
If selected candidates B0 - B3 fail and it is known B0 and B1 have high integrity. Could brute force B3 - B6 as a second try. Brute forcing four bytes could take up to 1.6 hours but that is a lot less time then Vdash cracking a P3. It would not be desirable but would be acceptable to end users. ( If one can accept up to 24 hours, one can accept ~ 2 hours time ) .solitaire wrote: 08 May 2021, 03:46 bruteforce again with first two and next candidate (3) from list
If going this route, an abort option that will also reset the CEMs would be a nice feature.
Active
Past
Past
solitaire
today tested with different voltage from power supply
14V from labor power supply: 3 times - 3 correct result with sample 9
11V from labor power supply: 3 times - 3 incorrect 3 bytes, but 3 bytes always in candidate 1-5
vtl please add to OLD code:
if PIN not found, try 3 byte next candidate
or please add additional code simple bruteforce if known 3 bytes,
thanks!
thanks!
- 9483 Views
Last post by RickHaleParker
- 9599 Views
- 27 Replies
- 29680 Views
Last post by cn90
- 11168 Views
Last post by jonesg
- 6272 Views
