- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Never had noise before engine replacement.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
To address what someone suggested earlier: If the subframe bolts were loosened then that boot at firewall for steering shaft could easily have popped off. I have knocked them loose doing things I thought surely would not have done it.
There are certainly some noises turbo cars make that Volvo didn't mean for you to hear.
- E Showell
Subframe bolts were loosened. I'll check the boot.
'95 855 auto (sold)
'95 855 auto (sold)
- Has thanked: 1613 times
- Been thanked: 4078 times
99 S70 NA FWD Auto, black (sold and resurrected -- Don't cry for me Argentina . . . )
She Is still headed back to Smith College Wednesday
- E Showell
Good luck to her. Taking the car?
Changed oil in Ruby Red to Castrol Edge Belgium-made 0W40. Wondering how it'll do.
'95 855 auto (sold)
'95 855 auto (sold)
- E Showell
Tightened the hood bump stops on the R. No change in hood release lever action.
'95 855 auto (sold)
'95 855 auto (sold)
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
Couple thoughts.E Showell wrote: 01 Sep 2019, 17:42 Tightened the hood bump stops on the R. No change in hood release lever action.
Wait til it gets colder out, it does help. And your cable is probably in need of replacement.
Over time the cable & its “steel-coil” sheath does lose lubricity, rust sets in, resistance builds etc.
When I replace them I lube the latches too.
Might just wanna order a new cable & replace it.
- OR -
Was the hood hard to get released prior to the engine transplant?
It’s entirely possible that when they were putting stuff back into the engine compartment the cable got pinched slightly between to things it was not previously pinched between.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- E Showell
No lever problems prior to engine replacement.
'95 855 auto (sold)
'95 855 auto (sold)
- E Showell
Also noticing oil residue weeping from hole in OTE charge pipe. Normal for there to be oil in there?
'95 855 auto (sold)
'95 855 auto (sold)
Normal for oil to be in the induction path. Inside of hoses can be moist from oil, but shouldn't be sopping wet. Paper towel will pick up oily residue. The turbo blows some oil out of its bearings and creates some mist which deposits throughout - also why throttle body cleanings are important.
- 12198 Replies
- 1684776 Views
Last post by RedBrickCollector
- 97 Replies
- 210475 Views
Last post by br0dy519
- 59 Replies
- 62551 Views
Last post by smacknab
- 7109 Views
Last post by xHeart
- 12349 Views
