- Has thanked: 1613 times
- Been thanked: 4078 times
Put 5 new Volvo plugs into Evita, then troubleshooting the Bavarian Money Waster for limp,mode…
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
I just realized, I've owned 3 of the rarest P80s (in NA). A 98 S70 T5M, a 98 V70 T5M, and a 99 S70 AWD. I guess that settles it, I have to buy an R to have Volvo BINGO!
Knows enough to be dangerous
- Has thanked: 317 times
- Been thanked: 531 times
You need to track down a rare color R too... saffron maybe? Or you could track down maybe the 1 cassis purple R in the world
I owned that same set all at once, briefly. Sort of. Donated the 98 , still driving the 99 T5M and 99 S70aWDWhatAmIDoing wrote: 28 Jan 2023, 19:11 I just realized, I've owned 3 of the rarest P80s (in NA). A 98 S70 T5M, a 98 V70 T5M, and a 99 S70 AWD. I guess that settles it, I have to buy an R to have Volvo BINGO!
- WhatAmIDoing
I almost bought a Saffron S70, but it suffered a timing belt failure.bmdubya1198 wrote: 28 Jan 2023, 22:42 You need to track down a rare color R too... saffron maybe? Or you could track down maybe the 1 cassis purple R in the world![]()
Woah, saffron S70? Where did you find that? Must have either been imported or painted.
Code 435
- 67F519CB-D498-4C12-A84A-47ABECEF0C70.jpeg (207.19 KiB) Viewed 433 times
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
Were only Saffron V70's imported to North America?bmdubya1198 wrote: 29 Jan 2023, 07:37 Woah, saffron S70? Where did you find that? Must have either been imported or painted.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- WhatAmIDoing
It was somewhere near Philadelphia a long time ago, if I'm remembering correctly. Wasn't too interested in engine swaps back then
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
Car took 1 slighlty extended crank yesterday and more extended today. I suspect injectors or fuel pressure regulator is going out. Will pull the entire rail from the crashed car and swap in. The fuel relay was swapped and known to be good. Ran injector cleaner through it recently, headgasket sealant in the coolant which worked about 2 weeks ago (400-600 km ago) and i did note a little buildup of residues around injector and especially around the fuel pressure regulator.
Will post if it gets worse
2008 S60 2.5T Auto (Sold)
