Not sure what pin you're talking about....describe further?
I've been struggling with A/C doing the same on mine...it apparently has a leak, but can't detect where's it's coming from....added a can a month a year ago and this summer, every 2-3 weeks. On a hunch I just added PAG oil 3 weeks ago and it's been absolutely fine since then. Don't know if o-rings and such were hardening up from a loss of oil or not, but maybe the PAG oil has done its trick to softening things up a bit. Anyway, I figured I had lost some out of the system anyway due to the many times it leaked and my re-fills.
If that's not it, then I know I'm in for an Evaporator, probably next summer (just trying to make it through A/C weather for now).
Official AC Thread
Volvo Air Conditioning Problems & Fixes
- Has thanked: 17 times
- Been thanked: 35 times
chuckcintron
- Year and Model:
I'm having a heck of a time identifying the AC compressor on my 1997 850 GLT. It has what appears to be a date code on it, indicating that it is original -- but the only identifying marks I can find on it are:
D907-0647 and the number "15" inside a circle.
No label of any sort indicating the manufacturer. I'm changing the evaporator and accumulator, so I need to know which viscosity of PAG to use.
I saw that it was stated that all 850s use PAG-46 oil. However, the dealer says that "it depends" based on whether the compressor was built by Seiko, Sanden or Zexel.
Is it true that PAG-46 is the likely answer? I really wish I could positively identify this compressor...
-Chuck
-Chuck
1997 855GLT
chuckcintron
- Year and Model:
Well, I did a little experiment...not sure if it's valid, but I went with it.
I filled up a small plastic cup with oil that I drained out of the old receiver/drier.
I filled up a second plastic cup with the same amount of fresh PAG-100 oil. I filled up a third cup with the same amount of fresh PAG-46 oil.
Next, one at a time, I poured the oil out and started a stopwatch when it turned from a stream to individual drips. I counted off twenty drips, then hit stop on the stopwatch.
My unknown original oil seemed to clock a lot closer to the PAG-46 than it did to the PAG-100 -- so I concluded that it must be close to the same viscosity.
Anyway, I hope this old viscosity test from my (years ago!) youthful days as a car painter still works, this time with air conditioner compressor oil instead of PPG catalyzed paints...
-Chuck
-Chuck
1997 855GLT
Just thought I'd add an update. I bought the Duracool tune up kit and did the conversion in May. I have had no leaks (have a pressure gauge) and man oh man has it been putting out cold air. My 850's a/c system works better than my 2004 Nissan or wifey's 2002 Santa Fe. I guess I'll have to wait to see if any leaks out over the winter, as I suspect I probably had a small leak somewhere which now seems to have been plugged. Beats the hell outta pulling my dash apart again...
1993 850 GLT
Close to 360,000 km
Close to 360,000 km
chuckcintron
- Year and Model:
I have to read up on that stuff some more. I did end up doing my evap replacement, so I'm good now with my charge of 134a -- but I've heard a lot of good things about duracool and it's efficiency over 134a.
I'd have to convince myself that running propane is safe...I don't think anyone's been blown up yet by their duracool ac system...but I don't want to the be first, either
-Chuck
-Chuck
1997 855GLT
greasefingerss
- Year and Model: 850 wagon 1994
I recently replaced my compressor. I pulled a vacuum on the system first, and then I added 1 and
Current Vehicles
1994 Volvo wagon(855) na 161,000 miles with AT
2003 Toyota Camry
1994 Jeep GC 202,000 miles
2003 Toy 4Runner
2003 Toyota Camry
2003 Toy 4Runner
I think the quantity is total for the entire system. Yeah, the gap is too wide. See if you can shimmy it to be less.
Btw, I had to add a can of gas this past weekend. Although adding oil helped my system, it certainly did not solve my problem. If I can get through the rest of this hot weather, then I'll deal with the A/C system before the next warm/hot season next year.
- 33 Replies
- 11559 Views
- 26 Replies
- 7843 Views
Last post by MoVolvos
- 31 Replies
- 13624 Views
Last post by ToriWhite
- 13040 Views
- 11 Replies
- 19525 Views
Last post by volvolugnut
