Dist cap I am specifically thinking about a leaky cam seal dumping oil in there, but sure it could be dirty for other reasons. Main point is to look at all ignition components. There are many threads on here about engines that run like crap, with or without misfire codes, and the problem traces back to ignition. How old are the wires? There will be a date code on them.
O2 sensors, ECT sound fine, that's good. How was the cat checked? Unless it was checked, I wouldn't assume it is fine.
FPR the idea is whether or not the fuel system holds pressure, not if it leaks.
Problem after transmission fluid change
- Has thanked: 292 times
- Been thanked: 765 times
Re: Problem after transmission fluid change
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
Francois850
- Year and Model: 97 850 Non Turbo
Well was telling you that I changed the fuel filter since you asked what I changed... "I don't remember what all was done recently on your car"
I will check ignition parts and see how that goes...
- regent
- Has thanked: 2 times
- Been thanked: 12 times
FPR = Fuel Pressure RegulatorFPR the idea is whether or not the fuel system holds pressure, not if it leaks.
You may want to verify that the system maintains pressure
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
Francois850
I don't have a way to check the fuel pressure at home. Btw, the FPR I believe is close to the fuel filter correct? I think it is, this is a 97 model....
I ordered a new distributor cap & rotor (Bosch),the ones on the car now are both original so won't hurt to replace them.
Also ordered 2 transmission cooling lines to reconnect the trans to the radiator. I am aware that if the trans is faulty it won't fix the problem but I need them anyway.
It's really hard to go about this issue when I don't have a single code to work with but... in time, it will be fixed.
If you guys have more ideas....
Francois850
I have been busy and still did not take the car to the trans shop, but I checked under the battery and the trans was connected to a small radiator which is in front of the main one so the trans was actually cooled, I guess the last guy who replaced the trans made that modification.
I was wondering, under the battery holder, what is that pump? Is it the air pump? Kinda looks dirty, I will check all connections etc...
Thanks
Thanks
The small device that is connected to the underside of the battery tray itself, is the vacuum pump for the cruise control.
The air pump is also down in that area. The air pump is larger, down lower (closer to the ground), like a half the size of a gallon milk jug, and connects to the body of the car. E.g. Air pump fix tutorial volvo.
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
Francois850
Cool, thanks for the quick reply...erikv11 wrote:The small device that is connected to the underside of the battery tray itself, is the vacuum pump for the cruise control.
Francois850
Hello, been out of town so little time to get the car worked on....
Anyway, here is an update, car still runs like hell.... doubt more and more it's a transmission issue.
Tonite I drove it a bit and finally the check engine light came on!!!
P0410 "Secondary Air Injection System Malfunction"
I guess it has something to do with the air pump etc... but would this affect how the car runs, accelerates, etc.... ???? Thanks!
The p0410 is a very common nuisance code, the SAS valve goes bad and the air pump fills up with water. So 99% of the time that code will not affect how the engine runs. An exception is if there is a vacuum leak somewhere in the SAS system, that is bad enough to affect air:fuel mixture.
So in short, check for vacuum leak, otherwise the p0410 is a red herring. In the meantime reset the code and check the air pump, but I wouldn't get too excited about that particular code.
This really reeks of something electrical, all those earlier posts you were saying it gets worse when the car is warm (is that still true?). So if the ignition system has been checked out by now, maybe even if it hasn't I would try testing the MAF. Easy enough to do if you haven't already: with the car off unplug the MAF, then start it up and drive around. If the symptoms are gone, the MAF was your problem. Will set a code you can just clear it.
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
Francois850
The MAF had issues in the past and the symptoms were totally different. I put a new few months ago (OEM Bosch) and it fixed the problem I had.
When I release the gas pedal, I hear a very faint hissing sound... leak?
I am excited when a code is triggered because so far, since the issue, I never got a single one!
I also did that stall test where you put the car on D and hit the brakes and then go full power, i get 1600 RPM max instead of 2600. Based on what I researched, it points to 2 issues : the torque converter is shot or the catalytic converter is clogged...
- 16 Replies
- 3541 Views
Last post by fourteen2hands
- 1225 Views
Last post by robrike
