Getting only 15-16 MPG combined driving...
TheLoneAviator
- Year and Model: V70 1998 AWD
Well, I've decided out of necessity to tear back into the old V70 to try to find the small Evap leak CEL issue AND fix the fuel mileage at 14mpg issue. I thought I would check the fuel pump and was prepared to do the cut out mod and surprise surprise someone else has already done that. But it looks like I did find my mileage problem AND possibly the Small Evap leak problem. It looks to me like the Fuel Pump Gasket is Leaking. See Photo.
TheLoneAviator
OR...
Do you gentlemen think it may be leaking FROM the Wires where they go into the pump causing the fuel to leak out & the Vacuum leak also?
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
If the grommet that is supposed to seal it is bad, yes it could leak there, more suck in as level drops I would assume, than fuel out unless tank was full. Good find! Always the last place you look, right
Current Volvos:
TheLoneAviator
I believe it was leaking from the wires feed thru. I potted it with Seal All. Definitely a vacuum leak for the tank press. Time will tell if there's any other source leak.
TheLoneAviator
Pulled the LF wheel & liner to inspect the Purge valve under the fender by the door, found the 90* hose on top of the canister had a crack I couldn't see from underneath. One more source out of the way.
code cleared, drive-som-mor...
TheLoneAviator
I quit. I'm trowing in the shop towel. The car is for sale NO RESERVE on ebay.
http://www.ebay.com/itm/181637913782?fo ... &viewitem=
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Listing ended early by seller due to error in listing . . .
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- 5768 Views
Last post by gnalan
- 627 Views
Last post by jonesg
- 2926 Views
- 12 Replies
- 1383 Views
- 28 Replies
- 4168 Views
Last post by RickHaleParker
