PCV Write-up for 1999+ Volvo 5-cylinder 31325709
jmartin919
Year and Model: S70 GLT SE 2000
Has thanked: 97 times
Been thanked: 42 times
Post by jmartin919 »
Exactly
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
Has thanked: 2203 times
Been thanked: 1852 times
It looks like the lower end has 2 wedged ends that hook into the 'trumpet' end of the connector. The other end just looks like it clamps around the pipe. Not seen this on a Volvo before, but 01-04 C70's are not something I have worked on.
Thanks for the info.
jmartin919
I didn't have one on my 2000 S70 Turbo but I was at the junk yard and saw one on a 2000 S70 NA so I grabbed it and put it on mine. Looks important anyway.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
DamianB
Year and Model: '00 V70 & '01 V70
Post by DamianB »
jmartin919 wrote: 03 Oct 2023, 17:29 I didn't have one on my 2000 S70 Turbo but I was at the junk yard and saw one on a 2000 S70 NA so I grabbed it and put it on mine. Looks important anyway.
My 2000 V70 Mk1 B5244S doesn't have it either, but 2001 V70 Mk2 B5244S does 🤷‍♂️
mh231
Year and Model: 99 V70 NA
Post by mh231 »
Hi everyone,
I'm preparing to do this on my 99 V70 with engine: B5254S.
I didn't see anything mentioned on this write up about it, but other threads have made mention of a banjo bolt and how difficult it is. Where is this bolt located?
Second, I have read on multiple threads of people using 5/8'' heater hose instead for better crankcase flow. Is there truth to this?
This is my first volvo and ive never done a replacement this involved yet so I definitely don't want to complicate. Just tying to get a clear image before starting this
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
Welcome !
I'd say that you should just use the PCV hoses that come with the kit. No reason to use larger diameter hose unless you have major blow-by issues. And I wouldn't use heater hose in that application regardless. It will break down over time. Use silicone hose for that sort of stuff.
Can't help regarding the banjo bolt.
1999 V70 GLT
rrres
Year and Model: 1999 v70XC
Has thanked: 12 times
Been thanked: 34 times
Post by rrres »
mh231 wrote: 21 Dec 2023, 08:23 ...I didn't see anything mentioned on this write up about it, but other threads have made mention of a banjo bolt and how difficult it is. Where is this bolt located?...
There are two. Item "D" in the diagram. The difficult one is the one on the intake manifold, because there is an alternator directly below it that is in the way.
PCV Diagram Color Coded.jpg (85.61 KiB) Viewed 399 times
It's blowby
Has thanked: 1610 times
Been thanked: 4068 times
There are a couple of ways to trick the under intake manifold banjo bolt installation.
It’s made difficult by the two copper washers you have to keep on it , and the hose has tension on it, and it’s an odd angle which is hard to get started ..these three things and the alternator conspire to make the CarDevil giggle with joy,
Removing the alternator ( and sending it out for rebuild) makes it a lot easier.
I usually install the banjo loosely on the intake manifold before I put the IM in place , then install the hoses onto the PCV hose onto the PCV box and clamp that next, then the water hose to the thermostat housing last
