1998 S70 T5 Low Compression after stall, will not retart
pfeener
Been thanked: 2 times
Post by pfeener »
Just so we're clear; the "valve cover sealant" is just that meaning it's for the valve cover. The head gasket normally goes on dry.
Trilarry
Post by Trilarry »
Yes I did order the $13.00 tube for the valve cover, I recieved it with my headgasket set. I thought the headgaset sealant went on dry, at least it did on my 242 turbo. This is the first valve cover that I will only use sealant to install. Did anyone use a special tool to keep the camshaft pulleys on spot? What did you use Greasefingers?
Tri
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Trilarry wrote: Did anyone use a special tool to keep the camshaft pulleys on spot?
The Haynes manual shows you how to make a tool to do this. Do you have a copy?
Trilarry
Post by Trilarry »
I only have a Chiltons Manual, I believe I seen a picture on a forum made fron angled aluminum.
Tri
Yeah...that's the one. I'll hunt for it too and post it back if I find it.
greasefingerss
Year and Model: 850 wagon 1994
Post by greasefingerss »
I did not use anything to hold the cams still. They do not move that easy. If you bump into it with your forearm, let
Current Vehicles
1994 Volvo wagon(855) na 161,000 miles with AT
2003 Toyota Camry
1994 Jeep GC 202,000 miles
2003 Toy 4Runner
pfeener
Post by pfeener »
If you're having problems slipping the belt past the crank pulley, you can always remove the crank pulley(not the sprocket; just the pulley). I always remove the crank pulley when I change my timing belt. It just makes the job so much easier and I can see what I'm doing.
greasefingerss
That huge crankshaft nut looks like serious business! I did not have an impact wrench as well. Can you get it off without air tools?
There are also four perimeter bolts on these pulleys. I assumed that they are to keep both the crank shaft pulley & the crank shaft gear moving in sync. I will feel like a dummy if you tell that the four small bolts hold the pulley on the shaft :oops:
Current Vehicles
2003 Toyota Camry
2003 Toy 4Runner
pfeener
Post by pfeener »
Yes the four smaller bolts hold the pulley on. Just remove them and put a puller on the edge of the pulley and it'll slip right off.
greasefingerss
D
Current Vehicles
2003 Toyota Camry
2003 Toy 4Runner
