New Volvo 850 Purchase!
- Been thanked: 4064 times
Everyone inEU is wondering why we drive with 900 mL size cups right now…
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
I'm not even using a travel mug, just the gas station disposable cup. It just feels very precarious to me, when maneuvering around town. I don't want to end up with coffee in my passenger seat. The biggest issue is leaving the gas station where the driveway is downhill, and the road is 90 degrees to it, going up hill. Then the bumps as I'm turning onto the highway on ramp. When driving my Saturn, the car has enough side to side movement to slosh the coffee out of the cup a bit, so the whole cup tumbling out of the Volvo cup holder is a real concern.foggydogg wrote: 22 Jan 2022, 09:52 I don't think the Swedes had 'Murican style travel mugs in mind when they finally, reluctantly, started putting cupholders in the cars.
I've been holding on to the coffee while in the Volvo, but I could really use two hands on the wheel at this point, due to traffic, and tight maneuvering as the driveway is near the intersection where I have to turn left across traffic.
Oh, so this is a known vendor! I'll look for Robert's video.Alex is an interesting character, and Swedish Car Parts just got in some leather seat skins for 850 Rs. Robert Spinner spends a good bit of time there when he's in Chicago.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
454cid
My HVAC filter frame/holder arrived today. I purchased it used through Ebay. I cleaned it up, and installed a new Mann filter. I had already vacuumed out the area a few days ago, when I discovered the need for the frame.
I also replaced the rear brake pads. The ones I removed were Volvo branded and had very little friction material left on them. I also found stainless steel shims in there. I reused the shims with cheapy pads, as the rotors really could be replaced. I'll likely do that when it gets warm out.
I have a bit of squeal when coming to a complete stop, and had hoped it was the rear brakes, but it's still there. The fronts look like they were replaced not long ago... any ideas?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Could be something as simple as poorly bedding the new pads under previous management.
This is the way I was taught to do it, many long, long years ago...
https://www.wagnerbrake.com/technical/t ... ak-in.html
Maybe if the weather cooperates, have the front pads out, knock off the glaze, and rebed.
- jmcguire
- Year and Model: 1996 850 Sedan
- Has thanked: 19 times
- Been thanked: 9 times
I chased a rear brake squeal a while ago. Replaced the brake hardware and greased the slide pins for the rear calipers. Also, cleaned the calipers with a wire brush and painted them a gloss black to keep them from rusting. Squeal went away and hasn’t come back.454cid wrote: 22 Jan 2022, 17:39 My HVAC filter frame/holder arrived today. I purchased it used through Ebay. I cleaned it up, and installed a new Mann filter. I had already vacuumed out the area a few days ago, when I discovered the need for the frame.
1996 850 Sedan
454cid
These calipers don't have slide pins, that I saw. They've got a piston for each pad. I've never seen calipers like this before.jmcguire wrote: 23 Jan 2022, 07:28I chased a rear brake squeal a while ago. Replaced the brake hardware and greased the slide pins for the rear calipers. Also, cleaned the calipers with a wire brush and painted them a gloss black to keep them from rusting. Squeal went away and hasn’t come back.454cid wrote: 22 Jan 2022, 17:39 My HVAC filter frame/holder arrived today. I purchased it used through Ebay. I cleaned it up, and installed a new Mann filter. I had already vacuumed out the area a few days ago, when I discovered the need for the frame.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- jmcguire
Maybe the problem is that the pins are missing then?454cid wrote: 23 Jan 2022, 08:28These calipers don't have slide pins, that I saw. They've got a piston for each pad. I've never seen calipers like this before.jmcguire wrote: 23 Jan 2022, 07:28I chased a rear brake squeal a while ago. Replaced the brake hardware and greased the slide pins for the rear calipers. Also, cleaned the calipers with a wire brush and painted them a gloss black to keep them from rusting. Squeal went away and hasn’t come back.454cid wrote: 22 Jan 2022, 17:39 My HVAC filter frame/holder arrived today. I purchased it used through Ebay. I cleaned it up, and installed a new Mann filter. I had already vacuumed out the area a few days ago, when I discovered the need for the frame.
They are shown on the left of the photo at this link:
https://www.ebay.com/itm/For-1993-1997- ... 632-2357-0
1996 850 Sedan
Fixed calipers are an older design from floating calipers but aren’t rare on some makes. They ar e better in wet environments as they don’t freeze up or stick like floaters.454cid wrote: 23 Jan 2022, 08:28These calipers don't have slide pins, that I saw. They've got a piston for each pad. I've never seen calipers like this before.jmcguire wrote: 23 Jan 2022, 07:28454cid wrote: 22 Jan 2022, 17:39 My HVAC filter frame/holder arrived today. I purchased it used through Ebay. I cleaned it up, and installed a new Mann filter. I had already vacuumed out the area a few days ago, when I discovered the need for the frame.
If you buy cheap parts though, they will rust up and stick
Cheap = Amazon eBay Rock auto pep boys advance oreillys
454cid
I thought you meant the pins that the caliper would slide on. I do have the pins you're referring to. I just installed new ones. I guess the pads do slide on them to an extent, but their main function seems to be pad retention. I put anti-seize on the ends, but didn't put anything on the exposed middle.jmcguire wrote: 23 Jan 2022, 08:36
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
454cid
I can see why Volvo would use them in the rear then.abscate wrote: 23 Jan 2022, 09:26 Fixed calipers are an older design from floating calipers but aren’t rare on some makes. They ar e better in wet environments as they don’t freeze up or stick like floaters.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
