xyna
- Year and Model: Volvo 740 1990
Took off my door panel to discover that my window regulator motor was broken in half. Replacing it went pretty good, considering that it was my first time. Wouldn't want to do it again, though.
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
Hi,xyna wrote: 01 Mar 2023, 09:17 Took off my door panel to discover that my window regulator motor was broken in half. Replacing it went pretty good, considering that it was my first time. Wouldn't want to do it again, though.
Any photos or videos?
That helps other people learn how to do it too.
- Has thanked: 2212 times
- Been thanked: 1853 times
Not sure what car you were working on? Do you have an 850 or V/S70 up to 2000 year? Your details say you have a 1990 740.
I am also curious as I have never heard of this issue on a P80 Volvo.
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
Placed an order for some used hella 7 in offroad lights. 4 at 25 a pop with 4 covers. Clear lenses so i am curious to see the beam pattern.
The plan is to mount 2 of them on the egg crate grill to give me a bit more distance on the highway. If the glare is too high then i will mount them at foglight level similar to how semi trucks run around up here. For the next two years a good amount of my highway driving will be through unlit areas so i want the peace of mind.
Depending on the brightness i am debating putting in LED or HID's in them. I might tape off half the lense to stop upward reflection, or just angle the lense down.
2008 S60 2.5T Auto (Sold)
- Has thanked: 1613 times
- Been thanked: 4075 times
Stock headlights are great on these cars if the reflectors are in good shape.
TYC make decent replacements for about $120 if needed.
yanga001
I already retrofitted projectors in my car which helped a lot. Issue with my area is the wet makes the lines next to invisible. You need bright lights contacting the surface to see what lane you are in. I got like 4 sets of headlights so maybe it would be worth a try.abscate wrote: 02 Mar 2023, 00:19 Stock headlights are great on these cars if the reflectors are in good shape.
xyna
Unfortunately I didn't take any photos as I just wanted to get the job done as soon as possible. I followed instructions from this website: https://www.pelicanparts.com/techarticl ... cement.htmMrAl wrote: 01 Mar 2023, 11:56Hi,xyna wrote: 01 Mar 2023, 09:17 Took off my door panel to discover that my window regulator motor was broken in half. Replacing it went pretty good, considering that it was my first time. Wouldn't want to do it again, though.
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
I grabbed my OBD2 Bluetooth device out of the 850, and tried it again in the 99 S70. It turns out that it won't talk to the Combi module, but it will talk to the ECC module. It says "ECC has 1 DTC: 13" and "ECC-322 air distribution damper motor position, no position change"WhatAmIDoing wrote: 25 Feb 2023, 19:38I was able to pull ECC codes in my 99 S70 AWD using 850-OBD2.454cid wrote: 23 Feb 2023, 20:52This one is ECC. Its changed output on me only once, since I bought it. I can't pull codes on it either since it's a 99 as 850obd2 wont talk to it.yanga001 wrote: 23 Feb 2023, 17:16
Had this issue with a 98 manual climate control system. Solved it by resoldering the pin connectors which restored defrost, AC activation, and other controls.
I'm not sure why it says one code, and then proceeds to give me what looks like 2 of them. I have no idea what DTC 13 is.
I didn't have time to try the other modules. When I tried the Combi I got a lot of buss errors.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- MrAl
Oh ok well maybe that link will help too, thanks.xyna wrote: 02 Mar 2023, 08:59Unfortunately I didn't take any photos as I just wanted to get the job done as soon as possible. I followed instructions from this website: https://www.pelicanparts.com/techarticl ... cement.htmMrAl wrote: 01 Mar 2023, 11:56Hi,xyna wrote: 01 Mar 2023, 09:17 Took off my door panel to discover that my window regulator motor was broken in half. Replacing it went pretty good, considering that it was my first time. Wouldn't want to do it again, though.
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
I'm not 100% sure on this since it's been a while, but I think the 2 digit code is the light flashes from the ECC when it has stored codes or it relates to the 850 diagnostic port pre OBD2.. So code 13 would correspond to ECC-322. What issue are you having? I don't remember the code, but mine was stuck on max heat. A known good module fixed the problem, which was the only troubleshoot step listed in VIDA for that code.454cid wrote: 02 Mar 2023, 10:45I grabbed my OBD2 Bluetooth device out of the 850, and tried it again in the 99 S70. It turns out that it won't talk to the Combi module, but it will talk to the ECC module. It says "ECC has 1 DTC: 13" and "ECC-322 air distribution damper motor position, no position change"WhatAmIDoing wrote: 25 Feb 2023, 19:38I was able to pull ECC codes in my 99 S70 AWD using 850-OBD2.454cid wrote: 23 Feb 2023, 20:52
I can't recall if I tried to talk to COMBI on my 99. What ELM firmware does you BT dongle run? I recall the author posting that some more advanced features require a later version than the minimum needed to talk to an 850.
Knows enough to be dangerous
