- Has thanked: 1613 times
- Been thanked: 4077 times
Aren’t the soft lines cheap enough to just take them off with the hard line brake job?
jsrnsis
- Year and Model: P80 enjoyer
- Has thanked: 25 times
- Been thanked: 71 times
Luckily on the passenger side they leave you a little bit of wiggle room in the hard line to make a new flare, but seeing that the hard line runs behind the gas tank, over the subframe, scares me for any future use of a hacksaw to unscrew a flare nut. The Y-shaped union on the drivers side was nice to see, except bending that short piece of line to the perfect angles to turn 7/8ths of a semicircle, down to the level of the bracket for the soft hose, with 2 inches of space that needs to hold the new flare nut and room for the flare tool, while having to constantly check that everything is still lined up.... If that brake line was available from the dealer, I'd gladly pay $40 for a $5 part to never do that again, but I don't even see it listed on the Volvo parts website.scot850 wrote: 26 Mar 2023, 23:09 I went to the Snap On flare wrench years ago when I found all other brands I tried rounded the 11mm brake line flare nuts. On an AWD P80 it is not worth thinking about damaging a rear brake line as it means dropping the rear subframe to replace it.
Yeah, I took all three bolts out of that subframe trailing arm, which needs a bit of prying and a jack to line back up, but at least it gave me a chance to spray some rust-reformer between that cast piece and the body. So you dropped that bracket/jack point to allow the vise-grip to spin where it would have previously hit the body?bmdubya1198 wrote: 26 Mar 2023, 23:02 I was able to use them on an AWD P80 rear brake line, but I removed that bracket just ahead of the rear wheel. It makes it a little easier. It looks like that bracket is supporting the subframe, but it's not.
That probably wouldn't be a bad investment! Most cheaper line wrenches don't seem to fit very well on these soft little brake line fittings.
I thought the Quinn flare nut wrenches would be better than Pittsburgh, but they seem too soft and just expand and slip over the nut if you try to give it a good turn.
1998 V70XC black 215xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
1997 850 GLT 125xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 125xxx
- Has thanked: 317 times
- Been thanked: 531 times
Yup, once I dropped that bracket, I was able to move the line far enough down to turn the pliers on the nut. This was on a friend's '99 V70R, I had to repair the line for him on the driver side, and it was tight, but we got it done.
- Clemens
- Has thanked: 501 times
- Been thanked: 228 times
Over the weekend I manual swapped my 96R and installed a Quaife and an ECU with a good tune.
Good lord, that thing is scary now ...
I'm glad the AW50-42 gave up on me a year ago or I probably would have never swapped it.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- Has thanked: 2215 times
- Been thanked: 1853 times
Well done Clemens! That is a big job, but clearly it was worth it!!
Fun! I'd love a Quaife in mine, but I don't plan on pulling the M56 back out anytime soon lol.Clemens wrote: 28 Mar 2023, 13:27 Over the weekend I manual swapped my 96R and installed a Quaife and an ECU with a good tune.
- Clemens
That quaife is awesome, but only if you have the tranny out.
Otherwise, removing the tranny is not worth it IMHO.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
Today I replaced the center cup holder courtesy of the parts car, filled ac 75% full including a small dose of dye, and I got most of the sunroof repasted with rtv (not a stationary type fix).
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
- astsb466
- Year and Model: 96 volvo 850
- Been thanked: 3 times
Today I changed front and rear crank seal ,and ı think most important seal is cam seal because for Volvo 850 there losting so much oil..under the cam position sensor.also I changed water pump..if ı dont change water pump maybe 3-4 days later I can changed all engine
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
Well i did the biggest job on a Volvo in the history of mankind today!
Yes, i changed the windshield wipers (ha ha).
A cheap pair this time so if stolen again wont lose much money.
Frigin' nasty b******s out there (the stars are not to bleep out the expletive it's because i didn't know how to spell that word (har har).
