Has thanked: 1505 times
Been thanked: 3818 times
ZionXIX wrote: 01 May 2023, 18:50 9Finally got the head pulled today on the xc90. I have a couple of questions since this is my 1st time pulling a head. Is it normal for each cam cover bay to be darker and more "cooked" looking from cylinder 1 to cylinder 5? When I pulled the head there were 2 sleeves sticking out of the cylinder block but there appear to be spaces for 4. Am I missing 2 sleeves? There are none in the cylinder head. It looks like 3 valves struck pistons for sure. It was pretty small though.
That #5 is badly coked up, I’m guessing from stem seals. Did it puff smoke on hard acceleration after a hill drop?
I’m not sure what sleeves you are referring to, hopefully not the cylinder sleeves
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
Sveedy wrote: 30 Apr 2023, 10:04
1)Take off the exhaust pipe, and smack it with a BMF hammer ( pipe is 3" s.s. ) to flatten it out a little on the bottom.
2)Use a couple pieces of bar steel to shim the cross member down, and drop that section of the brace.
3)Take it to an exhaust shop and have them bend and install a new section of exhaust pipe to clear the cross member.
4)Try and find a local therapy group for my on going " tinkeritis ", and hang the brace up on the shop wall as a reminder.
I think #3 would be the proper way of handling this, but it would cost some $ and since I am still skeptical of the benefit, #4 is currently ahead.
The stock car crowd have flattened header pipes and exhaust tubing for decades. We used to put a pretty good dimple in our header tubes right at the flange for header bolt clearance. The current NASCAR big boys run flattened exhaust tube exit pipes for ground clearance. Some years ago, Hot Rod mag did a dyno test with a set of headers they didn't cherish; after the baseline pulls, they started to beat a couple tubes closed to see what happened to the numbers. One runner was finally down to about 20% of the original diameter before they saw any gross change in horsepower.
Whack away.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
^ Thanks for that info Foggy. Good to know generally for working on any vehicle.
I only need apx 3/8"- 1/2" x 6" for clearance over that brace, which is way down stream, so I could put the pipe on a sand bag and easily flatten out that much, apparently with no adverse effect in performance.
3 or 4 good smacks with my dead blow hammer, and all should be good.
Thanks again !
1999 V70 GLT
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
ZionXIX wrote: 01 May 2023, 18:50 Is it normal for each cam cover bay to be darker and more "cooked" looking from cylinder 1 to cylinder 5?
I had a bit of this, not as dark, on my P2. It appears related to the distance from the oil pressure source at the end of the engine.
ZionXIX
Has thanked: 65 times
Been thanked: 194 times
Post by ZionXIX »
abscate wrote: 02 May 2023, 02:42
I guess the more accurate term is a dowel? It aligns the head and block together, sticks out a few millimeters. I only saw 2 dowels but it look like there is room for 4. I wasn't sure if this was evidence that the head has been removed before.
Ah, yes. They only come with two, I’m 99% sure. I’ll try link to pictures of my most recent valve job
On edit, on my T5 turbo motor there are 4 head cover locating pins. Let me know if you need some. I have an engine apart I can pull them, I think.
ZionXIX
Post by ZionXIX »
abscate wrote: 03 May 2023, 04:18 Ah, yes. They only come with two, I’m 99% sure. I’ll try link to pictures of my most recent valve job
That head looks so much better than mine. Every cylinder looks twice as dark as the one before. I assume this is due to extended oil changes by the previous owner or lots of idling and so forth.
I just dropped off the head at the machine shop for cleaning and checking.
yanga001
Has thanked: 59 times
Been thanked: 110 times
Post by yanga001 »
Picked up some Mobil 1 5w30 full syn for 35 cad. My rear mass motion sensor triggered a few times out of the blue. Will clear the back seats, ensure it is seated correctly, and hope for the best. Right now, the car is left in reduced guard mode.
Topped off coolant after timing belt change. Hoping to sort out getting a new bumper tomorrow or Friday.
2008 S60 2.5T Auto (Sold)
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 129 times
Post by 454cid »
yanga001 wrote: 03 May 2023, 23:19 Picked up some Mobil 1 5w30 full syn for 35 cad.
That's pretty light oil for a Volvo (according to the manual).
What does this mean? I've never heard any of these terms before.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Alarm stuff. They have to put a lot of alarms on Canadian cars because their southern neighbors keep coming up and stealing their cars and geese,
