Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
yanga001 wrote: 14 May 2023, 08:51 Started clearing the barn for the disabled v70. Anyone have luck with those castor wheel squares that you put cars on to car them inside. May help with positioning in my case.
I have a set ( 1500lb cap. ea. ) under my old full size Jeep pick-up. Easy enough to roll around, and then push back out of the way against the wall.
Look on CL. I see them there often.
1999 V70 GLT
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
I bought the cheapest ones from Harbor Freight several years ago. The first thing after getting them was to apply a thick layer of grease to the moving parts. After that I could move a light car (PV544 Volvo!) any direction with ease.
SOURDOUGHJIM
Year and Model: 2004 V70 2.4
Has thanked: 53 times
Been thanked: 27 times
Post by SOURDOUGHJIM »
I've owned the car less than a week. Getting along well with it so far. Today was wash and wax day. Also I fixed a semi-loose glove box door.
Has thanked: 1847 times
Been thanked: 1710 times
Glad it sounds like you found a good car to start with!
FireFox31
Has thanked: 158 times
Been thanked: 300 times
Post by FireFox31 »
NC855R wrote: 11 May 2023, 05:12 Spent this past Saturday at the LKQ yard in Greensboro NC to harvest an M56 swap. The car hit the yard 2-3 days before I got to it but was completely intact when I got there :). Feel bad for the donor car, it is a 1998 S70 T5M https://www.lkqpickyourpart.com/invento ... volvo-s70/ (VIN YV1LS5344W2424579) so from what I can gather somewhat rare.
Sad to see another T5M off the road but glad to know its valuable transmission is in good hands. Aren't there all sorts of extra parts needed for the manual swap such as things to enable cruise control?
Here's a list of parts for manual swap.
Go back and get those Perfo wheels!
454cid wrote: 14 May 2023, 01:00 Checked air in tires....850 was a couple pounds low in all 4 tires.
This reminds me: Why might one tire loose maybe 6 psi in a month (between monthly checks)? The local tire shop found no puncture but said they removed the tire and cleaned some corrosion from around the bead. Still, the tire has the very slow leak. I might have the wheel checked for damage at a different local shop. I watched them check another of my wheels for roundness on their machine. Made me confident that they have the right tool for the job.
FireFox31
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 129 times
Post by 454cid »
FireFox31 wrote: 14 May 2023, 20:54 This reminds me: Why might one tire loose maybe 6 psi in a month (between monthly checks)? The local tire shop found no puncture but said they removed the tire and cleaned some corrosion from around the bead. Still, the tire has the very slow leak. I might have the wheel checked for damage at a different local shop. I watched them check another of my wheels for roundness on their machine. Made me confident that they have the right tool for the job.
I don't have all that much experience with aluminum rims, but it's my understanding that they often don't seal all that well. I think they tend to corrode where the tire seats. When I had my Saturn it had aluminum rims, and I noticed that the front right tire would loose air faster than the others. I never had it checked for problem as I was getting close to getting rid of it.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Tires also seem to wear on the beads. I had a fairly fast leak along the beads on a spare in one of my BMWs, which I found in multiple locations around the wheel. Replaced the tire, problem solved.
A couple heat cycles may have helped, who knows.
NC855R
Year and Model: 1997 850 R
Has thanked: 45 times
Been thanked: 28 times
Post by NC855R »
Was surprised to see the wheels on the car, other LKQ yards around me seem to remove them, probably more money in scrap value. To be honest I was so knackered at the end I just wanted to get out before the yard closes "siren" sounded :) As for the extra bits, I got all the switches with the pedal cluster so if there is more then I'll have to source to rest.
jsrnsis
Year and Model: P80 enjoyer
Has thanked: 25 times
Been thanked: 68 times
Post by jsrnsis »
Decided to try this on a nice sunny day.
The neighbors must think I'm insane.
1998 V70XC black 183xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
Are you doing a full internal swap or is it just a sagging roof lining or such?
