Has thanked: 1614 times
Been thanked: 4078 times
And now you can take it back to Lowes for credit
:D
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
GlennG2759 wrote: 08 Nov 2019, 15:11 Iinstalled new ball joints in steering knuckles on my '06 V70. Used 2" by 4" galvanized pipe with cap, worked perfect. About half dozen shots with a 5 lb. hammer and they were home.
Saw some installed on Youtube and this is the best so far. Been looking for a better way as they all seem to angle in.
MoVolvos
Post by MoVolvos »
abscate wrote: 08 Nov 2019, 18:41 And now you can take it back to Lowes for credit
:D
Be sure to pipe down if they ask what you were going to use it for :roll: .
Greg, how was getting old ones out, did they pop out easily?
Just did an E83 front end and did one size with sockets and bashing ( blech) the other side my loaned out press was returned and it was machine shop joy,
GlennG2759
Year and Model: 2006 V70 NA
Has thanked: 112 times
Been thanked: 17 times
Post by GlennG2759 »
I used 1/4" x 10" brass drift pin, using a carpenters hammer and alternating shots on each side. One small pocket on each side is about the only place there is to punch at. If you make some king of holding jig for a vise it would probably only take a couple of shots on each side, I didn't but it would be nice. R & R took about 45 mins. Ball joints weren't that bad at all at 100k but since everything else was new I went with them (Lemforder). Also put them in the freezer for 2 days before, don't know if that helped with the ease of install. I've seen videos not recommending this as a DIY, it's relatively easy job. I've also seen it done while knuckle still in car, this I wouldn't attempt. On to inner & outer tie rod ends. Do you know if Mavis any good with Volvo alignment? Glenn
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
Today I removed the front passenger side carpet on 2001 V70. I suspected the pad was wet under the carpet and it was. Not socked, but wet on the edge. Left it out to dry and put in newspaper to try to locate where the leak is coming from. I cleaned the sunroof drains last week and they seemed to drain to the ground just fine. I did not get the back carpet up yet. I ran out of time.
Volvolugnut
- Pete -
Year and Model: 01, 04, 04, 04 V70's
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
Check your AC drain pipe while you're at it volvolugnut. There's a rubber elbow secured by a single, barely cinched zip tie (sometimes nothing at all).
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
RussB
Year and Model: '00 S70, '04 S60
Has thanked: 3 times
Post by RussB »
Put the snow tires on both the Volvos today...snow headed here in a couple days :shock:
'00 S70, '04 S60 and the never ending quest for Stage Zero
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
uh oh...
a3inverter
Been thanked: 9 times
Post by a3inverter »
Fourth drain and fill on my 2006 V70 in the last 20k miles (now at 155k). Stretched this one out to 7.5k miles and still a nice red. Next one in 15k miles. Seems like cheap insurance. Steering rack leak seems to have reduced to a couple of drips. Need to rotate the tires next weekend or put the winters on my existing wheels. Was thinking of getting the Harbor Freight manual tire changer to do it, but they're 17's...could be a lot of swearing and no success :)
