- Has thanked: 2212 times
- Been thanked: 1853 times
I prefer the manned (personned??) checkouts, so I must be one of the 'older people' you mentioned.
I can't be bothered to look up codes for different vegetables, fruit and bulk stuff. It also means I have to get my glasses out to read the screens, but I can see well enough for the cash/card payments.
- Has thanked: 317 times
- Been thanked: 531 times
scot850 wrote: 12 Aug 2023, 18:19 I prefer the manned (personned??) checkouts, so I must be one of the 'older people' you mentioned.![]()
- manovlov
- Year and Model: 1995 850 GLT 2.5 170
- Has thanked: 675 times
- Been thanked: 164 times
I repaired the wiring.
I have a cable i don't know what it is for. It comes from the square on the top of the ACC.
I have a second cable that seems to be plug to this first one (grey). I think they might be plugged together, no ?
I've replaced the hose on the top of the fuel tank the one that drives gaz upper the feed hole.
I've unbolted my rear wiper, its motor is dead. A used part normal this week.
I'm gaining more and more confidence in my maintenance work. And thanks to you guys!
- IMG_4714.jpg (43.37 KiB) Viewed 566 times
Yeah, that appears to be the clutch wire for the AC compressor.
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
Greased the edges of the rear brake pads to try to stop the squealing (seems to have helped a little bit -- time will tell), changed the engine oil and filter 10W-40 Mobil 1 and Mann, cleaned and reseated the connector on the MAP/Baro sensor (pn 1275342) after getting the P0108 engine code again -- had this once about 10 years ago... code hasn't come back yet.
Cleaning, cleaning, cleaning. Takes longer to clean stuff I pull from the junkyard than it takes to pull them in the first place. Vacuum bagging amplifiers units and cables, as well as another 2000 NA ETM after cleaning.
Also repairing an LH lower dash panel and under dash tray. Modifying the stupid flimsy screw retainer for the undertray with a strip of thin steel and a metal spring 'U'-clip for threading the retaining screw into which should be a lot stronger than the original plastic threaded piece that breaks off.
Finally tagging locations of parts on stock list and cleaning the remaining amp cables (removing the sticky residue from the foam covering). All that is left for the current hoard pulled is to clean the SC-901 unit including the laser for the CD player and then testing the small speakers, amp, cables and SC-901. Then I just have to clean some wooden dash pieces for a friend and organise to start packing for shipping!
- Has thanked: 1613 times
- Been thanked: 4075 times
Still trying to sort out the undocumented two part numbers for the 1998 99 00 purge valves
- P80GLT
- Has thanked: 154 times
- Been thanked: 176 times
Couple of pics (not mine) from the Dumfries show
I was captured giving the car a quick wipe over when I arrived. I left Glasgow and by the time I reached Kilmarnock the heavens had opened. When I arrived at Dumfries it was dry, even the grass was dry and we never saw any rain all day. Result...
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
Nice, parked right next to a MK3 Capri
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
