Parts brands - OE Volvo, trusted aftermarket, and bad
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 114 times
Post by Goupil »
jsrnsis wrote: 20 May 2024, 19:31
Part number CRP-AVE0621. Id avoid like the plague.
Sounds like the part number should be CRAP-AVE0621 :mrgreen:
I should check the state of the Febi I installed on my car 4 years/60 000km ago
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
I noticed that the turbo coolant hose (6842190) I used to be able to get for about $10 is now running in the $50 to $60 range. Is there any durable alternative to OEM?
Screen Shot 2024-05-29 at 19.01.42.png (245.46 KiB) Viewed 4214 times
jsrnsis
Year and Model: P80 enjoyer
Has thanked: 25 times
Been thanked: 71 times
Post by jsrnsis »
jreed wrote: 29 May 2024, 17:02 I noticed that the turbo coolant hose (6842190) I used to be able to get for about $10 is now running in the $50 to $60 range. Is there any durable alternative to OEM?Screen Shot 2024-05-29 at 19.01.42.png
Very unfortunate highway robbery. I should have ordered one for my blue wagon since I like going OEM for hoses like that, but the car came with a set of IPD silicone hoses for that hose as well as the one that runs over the heat shield. Looks like the two hoses together cost $20, though silicone in that oil-heavy area under the turbo might be asking for trouble.
EDIT: I found an answer to my question about part 9471700 that's for the 99+ cars.
1998 V70XC black 215xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
1997 850 GLT 125xxx
Has thanked: 1610 times
Been thanked: 4067 times
I would bite the bullet on that OE one Jreed. Rubber is a place where the cost cutting comes back to boil you over.
Volvo rubber seems to last 20 years plus and those turbo hoses are getting baked
Has thanked: 2200 times
Been thanked: 1852 times
I mentioned recently that the 3-4" long turbo outlet to metal charge pipe at the back of the P80 engine is listed for $150??!
A lot of Volvo prices have gone completely off the rails to the point of stupidity. I've already told my local dealerships I can't afford to by from them at MSRP + 30%!
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
Here's a weirdness I just came across. A basic XC70 windshield washer pump.
First stop FCP. Credit to them, they usually tell you a bit about parts manufacturers and sources. I would usually go Blue Box Volvo if I can afford it or especially in a critical system or hard-to-reach location. Here's what I've found and it's a bit frustrating:
VEMO $18 (cheap!) Italy
Pro Parts Sweden (STAY AWAY!) $15 Taiwan
Blue Box Volvo $90 (really?) China.....(REALLY?)
jreed
Post by jreed »
Yep, I agree... it's getting into the stratosphere for some of these older Volvo parts.
jsrnsis
Post by jsrnsis »
Bought a reman steering rack from Detroit axle due to a leak from one of the external lines that are NLA, and they sent this new aftermarket one that they also sell.
They said they can't guarantee a replacement with an OEM rebuilt unit, it might be rebuilt from aftermarket cores they received. Not sure we want to do the work to replace this just to have it fail in a year or two, but the leak is pretty bad and I think introducing air into the system causing a constant groaning sound.
Don't know who we'd buy from, Detroit axle had free core return labels and a lifetime warranty, but it's a lot of work to go through if it fails soon.
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 125xxx
I did a bunch of p80 racks during Covid and both Detroit and United racks have had no issues.
Ymmv
jsrnsis
Post by jsrnsis »
Still have yet to see how it holds up in the long run, but no immediate problems with the Detroit axle rack. The rack that came out was a rebuilt SMI rack, and belched fluid from both ends when I took the boots off.
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 125xxx
