Do you have the 2 liter/10 valve engine?Hello:
Last weekend I opened my 1996 car for putting a 94's body throttle with 65mm repaired plate and: My car has a 55mm throttle body with the plastic piece and the tube from the air filter is little for the new throttle body.
If I do the change to 65mm throttle, what things may occurs?
The car (should) compensate for increased airflow through the plate and match with the according fuel mixture, though I don't know how much power gain you would expect on that particular engine.
