I'm in serious need of a new engine as mine is on the fritz, If push came to shove would I have any problems using a 98+ engine IF I was to swap over all the other components? I'm not too sure on the specifics on the engine design but I don't see why it wouldn't work, or at least a 98. This will be going into my 850 with the motronic 4.4 so I'm not sure if it's more forgiving or harder to please or what, ANY advice would be great.
Thanks
-Josh
Putting a 98+ engine in a pre-98
VCA
- Year and Model: 2008 S80 T6 AWD
- Been thanked: 5 times
What year and engine 850? The short answer is 'probably not', because one of the big changes was CVVT, which was introduced in 1999. Your ECM won't be able to control the CVVT solenoid, so things won't work properly there.
2008 S80 T6 AWD
1999 S70 GLT
1999 S70 GLT
What if it was a 98, I think that's the last year before the engine management got an overhaul?
Also forgot to mention my car is a 97, so it has the SAS system as opposed to an EGR sysytem. Again, I'm not entirely familiar with the EGR system, so that may mean that I don't have it.
- Has thanked: 292 times
- Been thanked: 765 times
98 is exactly the same engine, accessories and everything, so no problem there.
Newer engines into an 850 or 98 x70 has been going on long enough that it is now all worked out and is a very popular swap these days. I haven't done it so don't know the specifics but it is clear from what I read that it is not that hard. Search "RN swap" on Volvospeed for hundreds of posts, here is a good one: http://volvospeed.com/vs_forum/topic/16 ... -rn-swaps/
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
