Start backing out your changes until it's running well, then re-add them one by one.Preiokas wrote: 04 Apr 2024, 02:22 My boost is now all over the place (overboosting to 1.1 BAR with the TCV trying to bring the boost down to 0.6) with the new Pierburg TCV and M4.3 ECU.
VS M4.4 tuning dead? Start again here?
- Has thanked: 2856 times
- Been thanked: 1332 times
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
What ECU is currently in the car? M4.3 or M4.4?
There shouldn't be any reason to need anything other than the -607 bin you flashed already.
M4.3 and runs great.Chuck W wrote: 05 Apr 2024, 07:45 What ECU is currently in the car? M4.3 or M4.4?
It's currently too cold outside to work on my car
Any help is appreciated if anyone can read what's wrong with the TCV duty cycle from the datalog from my previous post.
- Chuck W
Put the M4.4 and new TCV in the car (when you can) and report back.
Josya
- Year and Model: 1995, 850 T5
- Has thanked: 6 times
Hi!Chuck W wrote: 28 Sep 2023, 06:28 My stuff wouldn't be very useful to you.
As I mentioned, I'm running a WBO2 Modulation bin, so I don't have a VE map. It's an AFR Target map.
Also, my turbo control parameters probably aren't spicy enough for you. I'm only at about 12-13 psi. Mainly because I haven't had the time to really mess around with it, and the car is running great.
Dear Chuck, can you please send me BIN files for m4.4 from S/V/C70 with a mechanical throttle?
Maybe there were earlier discussions about the firmware for these cars that I missed.
Or maybe you had a tuned firmware for the 850 and the 15G turbine with automatic transmission.
Also, maybe you have a checksum file for S/V/C70 with a mechanical throttle for the TunerPro?
- Chuck W
Hi-Josya wrote: 15 Apr 2024, 05:52 Hi!
I have all of the files that were originally available on the M4.4 Wiki site (and stuff from the big VS thread on the M4.4 conversions), as well as the basic stuff for M4.3 tuning.
I ran my 854 on the basic M4.4 -607(VS) bin with the 15G, etc for a while until I did the manual swap/COP/etc.
Send me your email in the PM and I can send you all of that stuff to get you started with TunerPro.
Josya
Dear forum members,
do any of you have any thoughts about setting up the turbo table - TC Duty Cycle Pilot Control and Target Load Setpoint.
I can't understand the relationship between these two tables. TC Duty Cycle Pilot Control table has the same values, but the values in Target Load Setpoint table are different. At the same RPM and throttle opening angle.
How to set up a TC Duty Cycle Pilot Control for large values, while setting up the table Target Load Setpoint correctly
- Chuck W
As mentioned, the Target Load Setpoint is the desired engine loading (which is not boost pressure) and the TC Duty Cycle is how much/quickly the ECU allows the system to work to get to that point. Lower duty cycle values = slower response/build. (The TCV is basically a modulated bleed orifice to control boost signal to the WGA)
Read the M4.4 Wiki pages to get an understanding. Adjusting the boost control is also discussed there, on a basic and an advanced level.
An accurate boost gauge (and/or MAP sensor for data logging), along with a WBO2 sensor are key to avoiding engine damage and to actually see what you're doing.
Here is a quick explanation of what engine loading is, from the Motronic M4.4 PDF
Dudde
- Year and Model: 2005 V70 and more
- Has thanked: 16 times
- Been thanked: 17 times
Hi, i have 0261204293 ecu B5254S. Can i swap a 0261204570 ecu or how was the immobilizer on these M4.4? Don't remember myself. Or if anyone have any xdf for those it would be helpful.
- 4487 Views
Last post by TheMrFailz
- 13 Replies
- 12224 Views
Last post by SVO LOU
- 1285 Views
- 1154 Views
Last post by oragex
- 1624 Views
Last post by Swedeneed
