manovlov
Has thanked: 675 times
Been thanked: 164 times
Post by manovlov »
Hy Brunocerous,
Did you have a look at the throttle ? Issue with the gas pedal cable ?
Manov
Has thanked: 2215 times
Been thanked: 1853 times
Brunocerous's car he is working on is his 'Silver Bullet' which is a 2000 model. It has an ETM throttle body, so fly-by-wire, no throttle mechanical cable.
However, that is another good idea, there could be a throttle peddle position sensor issue.
Has thanked: 1613 times
Been thanked: 4078 times
850 LPT wrote: 24 Aug 2023, 06:38
abscate wrote: 23 Aug 2023, 18:38
850 LPT wrote: 23 Aug 2023, 18:28 If that V70 has an automatic tranny, check the fluid right away. Replace immediately if dark and burned. I would not be surprised if it overheated.
Trans shifted very well. Torque converter was locking up except on worst hills. Not too worried about it but will check in am
I killed the transmission in our 99'V70XC towing 2000lbs on a hot day when it was only 4 years old. It was a very expensive mistake to make.
No shifting issues, and fluid is sweet...b
Cutoff wheel looks a little spent, though.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
That fluid looks excellent. The cutoff wheel on the other hand...
Actually, use a grinding wheel to smooth that out and clean it up. It has a couple more cuts left.
FireFox31
Has thanked: 159 times
Been thanked: 303 times
Post by FireFox31 »
I run my little Dremel cut off wheels until they wear to the central metal collar. I feel that their smaller diameter allows for more fine work. Helped when I was cutting an O2 sensor out of the remnants of the exhaust hole. Pro tip: Don't cut it, use excessive heat.
FireFox31
I felt pretty Scottish using that wheel, but I did wear a full face mask expecting it to fly…..to PIECES ( Patsy Cline).
I’m guessing using one like that is a good way for facial adjustments
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
abscate wrote: 25 Aug 2023, 10:35
Hi,
Yikes, that cutoff wheel looks nasty. You are not supposed to cut diamonds with it. :D
It looks like it is ready for intense recycling. Smash it up into little pieces, then use globs of super glue to glue the tiny fragments back together on the pointed end of a nail, then cut off the head and stick in a drill. Makes a cute little fine point grinder.
Now why don't oil dipsticks look like that. Seems to me a nice bright color would show the oil on the stick better than having a dark metal color which makes it harder to see where the oil reaches up to. Maybe paint the oil dipstick with a special baked-on white paint?
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
+ 5 MVS points for Patsy Cline reference.
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
Gave the 850 a quick wash early this morning before heading out to Lesmahagow and the Auchlochan Car Show
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
brunocerous
Year and Model: 1998 V70
Has thanked: 303 times
Been thanked: 43 times
Post by brunocerous »
I’m back in Queens visiting my parents and hoping to work on the Silver Bullet’s ETM. I’ve got the Interstate battery out of Blue Steel and on a charger to listen again for the click and whirr of it initializing after having it repaired by Xemodex.
Thanks, FireFox31, for the ETM startup post. The Geronimo thread is amazing. viewtopic.php?t=98286
abscate wrote: 22 Aug 2023, 02:48 Might have some Queens time on Thursday this week. Have to pick up Caitlin inFort Greene after work Thursday pm, so could swing out earlier to beat traffic. I have a spare known to be good ETM , I think I can find it…
Thank you for the offer! It was a busy week at work, and I didn’t have a chance to even think about getting out here.
Update: Here’s video of the ETM while turning the key to position II. Is the throttle plate supposed to close entirely?
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
