Clemens
Has thanked: 500 times
Been thanked: 228 times
Post by Clemens »
What a busy Volvo week I had:
Got a new Bosch rear caliper. Put it on my 96 R. Put the old caliper from the R onto the 94 T5M. Plus new Zimmermann rotors and pads. Now the brakes are nice again. Prepped and painted the sheet metal hidden underneath the rear inner fenders on the 94 with POR 15. Quite some rust hidden behind them. Upgraded the stereo on the 94 to 6 speakers and a subwoofer for a total of 2 Euros because I had so much stuff left over from way back when. Charged the battery. Drained and refilled the ATF on the 96. As usual, the dipstick is a b...h to read. Drained 4.2 liters, refilled with 4 and seems to be high. Gonna drain again after the vavation. Replaced some atf oil from the PS reservoir. Ordered new gates timing belt and got a Mann oil filter. Drove 250 miles with the R and washed it. Still trying to hunt down noises while driving over bumpy roads. I am starting to believe they were noisy from the factory. Found the oil and tranny cooler lines to be rusty at the connections. I hate rust. Thinking about replacing the lines.
1996 855 R,
2010 V70 D5,
Has thanked: 1611 times
Been thanked: 4071 times
First meeting of Volvofest Albany in the Brooklyn Venue.
Good times had by all.
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
We forgot to take a picture and post it! :)
Retired:
2015 Volvo S60, T5, 85K
theWIFES_S70 wrote: 04 Aug 2018, 09:31 We forgot to take a picture and post it! :)
Yeah, one of us is in Communications and phoned it in..’
:D
bmdubya1198 wrote: 29 Jul 2018, 08:20 Well seeing your post yesterday morning is what made me decide "ah, what the hell." I grabbed some things for the R and the 740 at the junkyard yesterday morning and figured I would go ahead and yank it out yesterday afternoon so I could get it all back together today.
I'll see if I can find some butyl tape at Lowe's or Home Depot. I'll put some along the front edges of the dash. Anything to cut down on more squeaking sounds great to me! I want a silent dash! I'll deal with the trunk area noise later.
Next week I'll drop the headliner and re-glue it finally. I'll probably investigate then since I have to remove all of the upper panels.
Hahaha, I'll be passing both of you soon enough my friend!
June sw a clone of your car in MS
sventastic
Year and Model: 1996 854R
Been thanked: 6 times
Post by sventastic »
Replaced this sucker
And got IPD's HD Viton oil cap seal. Will be interested to see if this keep oil from leaking onto the cam cover. It's <1mm thicker but definitely snugs the cap up tighter
1996 854R | M56H | 16T | 274k | BC, Canada
Is that an upper engine torque rod? Thats a perfectly good tested used part...
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
abscate wrote: 04 Aug 2018, 10:47
Very funny! :lol:
sventastic wrote: 04 Aug 2018, 12:52 Replaced this sucker
Wow, that old one was awful! Was it a polyurethane bushing? It doesn’t look stock.
That iPd bushing should feel much better!
sventastic
abscate wrote: 04 Aug 2018, 14:54 Is that an upper engine torque rod? Thats a perfectly good tested used part...
Yes it is!
And yeah absolutely, it's it's totally in the bin with the other 100% still usable parts... :lol:
bmdubya1198 wrote: 04 Aug 2018, 21:30
Yeah I think it's poly based on it being a two-piece unit like the blue one that replaced it, I think it might actually be the older style of the IPD mount based on the previous owner's propensity for installing IPD-sourced parts
bmdubya1198
sventastic wrote: 05 Aug 2018, 04:18
Probably an older style. I see a lot of those bushings on junkyard cars, the problem with them is that the outer diameter is too small for the bracket, and they move around. I had that problem and I swapped it for a new Lemforder rubber mount (huge PITA to press in). I want to get the current iPd mount for my R.
