Thanks Abscate. I think I'm gonna try some local black permatex and just dab a little around the edge before placing the cam cover. For now I'm putting it on hold since I found one of tye camshaft sensor wheels broke.
Also I lost one of the idler bolts and had to come up with an alternate plan. I'm not proud of what I did.
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
- Has thanked: 1611 times
- Been thanked: 4075 times
Easily replaced when you find it.
You can test the depth of the block hole to see if that longer bolt won’t bottom out , too
Dr Dremel can also resize bolts for you. Put a nut on it first to chase the thread , post cut
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
Hi,abscate wrote: 31 Aug 2023, 00:32 Easily replaced when you find it.
Good idea with the nut. A little taper at the very end helps too to get the bolt started when screwing it in.
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
I broke the sunroof today. One of the arms that guide and heighten the sunroof as it raises to vent is broken. I managed to get it closed with some persuasion. Now I cant open it until Im ready to take a crack at it.
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
- Has thanked: 2211 times
Take the whole head liner out and the sunroof 'cassette'. You will be glad you did as it is a challenge to get access to some of it and some you can't disassemble without removing it all.
MVS legal has forced us to post a reminder that proper tools should be used…and safety footwear at all timesvolvolugnut wrote: 22 Aug 2023, 17:44 OK, the Zip tie spring compressor photo was fun, but PLEASE DO NOT USE ZIP TIES TO COMPRESS DANGEROUS SPRINGS!
You can get hurt or killed!
- IMG_1449.jpeg (106.06 KiB) Viewed 1094 times
I was watching a TV program about 2 brothers who get commissioned by one of the auto channel program channels to build unusual vehicle based on something they pull out of a barn or such. I was very disappointed to see the guys lift a pickup by the center of the rear diff, no wheel chocks, and no axle stands and start crawling under it! Wow, what a way to teach the newbies to car repair!!
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 278 times
- Been thanked: 85 times
I finally finished 2 rust repairs (tailgate and roof-antenna hole).
So I'm driving it again and again got a srs code <212 driver airb. Open c.> after it sat for a while. Meh, I ordered a used clock spring, maybe I'll try that as a fix when I feel like it. It seems to go away after I clear it until it sits again for a longer time.
Otherwise it is running fine
850 T5-R '95 auto
