bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
MoVolvos wrote: 05 Dec 2023, 09:40
bmdubya1198 wrote: 05 Dec 2023, 08:41
MoVolvos wrote: 04 Dec 2023, 23:10
Though the wire covering is now plastic it's not that bad in the sense that all 4 of our Volvos were worse. We just used harness tape and it was a done deal on all of them. Do not remove any of the broken pieces and just wrap.
Used a similar brand of High Heat Tape for under the hood. Have also use the more softer tape for wiring and harness inside the car. As a matter of fact we use the softer on the S70 wiring below. The High Heat Tape is good for plug wire and others next to the engine.
(www.amazon.com/XFasten-Harness-4-Inch-5 ... r=8-3&th=1)
While the wiring is good now, that headlight is done for. You probably get next to no light out of those reflectors!
Those reflectors were definitely shot. The pictures were from the October 16th 2022 post when the work was done. The lights are still okay after painting the reflectors and no wiring issues.
Project 2000 S70 SE - LEDS
viewtopic.php?p=611673#p611673
Ah, that's right. I remember that post.
abscate wrote: 05 Dec 2023, 03:05 Ran the Kat out of gas for second time in two days. Got distracted chasing a bad battery but then realized my Gauge is sitting at 2’ and AWD cars totalize , not average. I had put one gallon in to get home from the last , drove around for 25 miles, then ran out again.
Instead of chasing red herrings, I measured fuel pressure when stalled. 5-10 psi. Amazing
Runn8jg out of gas symptoms. Slight surging on 45 mph road, then power decline, rough idle m stall
Car will them crank, idle rough as the cavitation gets fuel pump delivers a bit of fuel to injectors, idles 5-10 seconds, stalls. No power, you can’t move car under idle
Too funny.
Abby amd I used solid tow bar method to retrieve car one mile from home , waited an hour for Universoty traffic to slack off until 6 pm, went home , ate pizza, came back and got her safe
I need to cut down a tall tree, so that herring will be useful
Too funny indeed... it's okay though, you didn't have to pay someone an hour of diag to tell you it was out of gas! Had to do that a few weeks ago... then the guy literally sold the car while it was in my shop. Hilarious chain of events... I should have charged him double for wasting my time :lol:
Has thanked: 1850 times
Been thanked: 1710 times
I guess? that is a bright side to the challenge.
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
levalexi wrote: 05 Dec 2023, 13:13 I took advantage of some sale on Walmart the other week and got both LHD and RHD OBX front strut bars. I think it was like 200ish shipped for both
The sale is still going on for those interested. My RHD brace arrived but the S70 is with my Son so won't be able to provide feedback for a couple of weeks. I'm tempted to get the LHD also just to see how well it fits? If you get yours installed let us know what you think?
Stainless Tower Brace OBD 2 Fitment For Volvo 850 T/C By OBX-RS
Now $78.40
You save $68.59
was $146.99
Shipping fee $22.10
https://www.walmart.com/ip/seort/1994946538
Now $48.80
You save $42.69
was $91.49
Shipping fee $22.10
https://www.walmart.com/ip/seort/1588503258
MoVolvos
Post by MoVolvos »
jsrnsis wrote: 05 Dec 2023, 14:09
scot850 wrote: 05 Dec 2023, 12:58 Well that certainly sucks. In context, these are near 25-30 year old cars in a rust area. We need to send you more positive thoughts to get you through this latest challenge!
So far the cascade of events being rusted fuel line causing low fuel pressure which caused a backfire which blew out the exhaust manifold which happened to be RTV'd in place and needed the cylinder head to come off as well as to replace some valve stem seals which has led to a broken head bolt. On the bright side, it's on the very front of the engine so it's the easiest to access.
Do you think a shorter bolt may work? Keep us posted on how you intend to solved that as it's pretty deep and probably frozen also.
Has thanked: 1505 times
Been thanked: 3818 times
Ooofla. I thought my week of idiocy running out of gas was a bad week... hopefully it drills out easily. Is there a good machine shop nearby?
jsrnsis
Year and Model: P80 enjoyer
Has thanked: 25 times
Been thanked: 68 times
Post by jsrnsis »
I'll start posting again in the thread I made for this car now that I'm back to working on it, but the bolt actually broke right at where the threads start in the block. There is a machine shop I've dealt with in the past so I always have that as a last resort.
Plenty of threads here and elsewhere about people getting these out, it seems it happens more than I thought.
1998 V70XC black 183xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
levalexi
Year and Model: 2000 v70 xc se
Been thanked: 6 times
Post by levalexi »
MoVolvos wrote: 05 Dec 2023, 20:35
Now $78.40
You save $68.59
was $146.99
Shipping fee $22.10
Now $48.80
You save $42.69
was $91.49
Shipping fee $22.10
The LHD should fit no problem. The RHD takes a bit of modification to the fuse box location and blocks access to the brake fluid reservoir. Possibly something else.
I attached a picture of the guys engine bay who is using the RHD.
STLV70
Year and Model: 1998 V70
Has thanked: 29 times
Been thanked: 5 times
Post by STLV70 »
I broke a blinker assembly while replacing the headlights. New blinker assembly on order. Current blinker assembly attached to frame with magnets I glued to the back of the blinker assembly. That should work for the time being. New headlights made a huge difference!
I took the cup holder apart to see how to fix it. It's got some broken innards, and it looks like I'm going to need a spring on the inside for one of the arms to swing out correctly. I think a small screw can serve as the post for the arm to swing on once I locate a spring. Until then, my passengers will have to hold their drinks while I use the functioning cup holder. :D
Got the car back from the mechanic with a list of new projects.
1998 V70 Base - "Lazarus" - 180XXX
2001 V70XC - "Gustav" - 200XXX
jsrnsis wrote: 06 Dec 2023, 07:36 I'll start posting again in the thread I made for this car now that I'm back to working on it, but the bolt actually broke right at where the threads start in the block. There is a machine shop I've dealt with in the past so I always have that as a last resort.
Don’t even Think about trying EZ outs, the Devils’ tinsnips.
If you own them, throw them into the Hudson
Pulled over to photograph some Canadian visitors and either hit something or. ???
Right rear tire blew out , sidewall failure. Tread about 3/32, but tires 13 years old. Time for new summers next year
