RedBrickCollector
Year and Model: 1997 850 T-5 Wagon
Has thanked: 40 times
Been thanked: 28 times
Post by RedBrickCollector »
Finally got tires for the Thors I picked up.
I know there's a few here running these wheels, what did you do for the center caps? My old ones won't swap over on the front.
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2652 times
Been thanked: 1241 times
Post by matthew1 »
RedBrickCollector wrote: 06 Jan 2024, 19:39 Finally got tires for the Thors I picked up.
That looks great. Just awesome.
Also -> Amazon link
Has thanked: 1500 times
Been thanked: 3812 times
There’s nothing like red paint, to say …. CAR!
It pays to obey the women in your life.
I must be a $7,000,000-aire by now….
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
Centre caps should be a straight swap over. I've swapped mine from my Columba wheels on my 850 to my Thor wheels on my V70 numerous times
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
RedBrickCollector wrote: 02 Jan 2024, 12:16 Noticed that my right hood latch wasn't latching, and that there was a missing bolt.
What I had thought would be a 5 minute fix turned into 2 and 1/2 hours, and a case of the right side not unlatching instead which almsot made me give up at around the 2 hour mark.
Not sure if this is normal but the whole thing just doesn't work unless the bottom bolt is a little loose.
Anyways as promised here's a pic of my subframe's "folded ear"
Having just watched MoVolvos video post in the " Ticking noise " thread, I think the folded ear might be due to someone removing the oil pan.
1999 V70 GLT
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
Do you mean it's loose, too tight etc... If you have difficulty buying them just wrap them all in some color or pattern that you like. Some of the caps I have are loose while other tight so have to use the butt of a wooden hammer to push them out.
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
Race cars don’t have center caps.
jsrnsis
Year and Model: P80 enjoyer
Has thanked: 25 times
Been thanked: 68 times
Post by jsrnsis »
Is there any workaround for discontinued part 9157320 and $100 part 9157321 for the AWD p80 rear suspensions? They're the bushings and support plates for the top of the nivomat shocks, and I fear that they may be going bad on my XC. I recently laid down the $600+ for new nivomats as I couldn't find a definitive way to side-grade to regular rear shocks and springs and keep the XC ride height.
1998 V70XC black 183xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
RedBrickCollector
The issue I have in front is that the threads for the axle protrude past where the center cap would go by a good 8-10mm. It seems there have been similar issues reported on the forum and the cause was stated to be because there's two different axle mounting types, one using a bolt and one using a nut. I'm on the nut type which leaves me with a lot of thread protruding from the Thors. I'm contemplating just cutting the thread but might go for raised caps instead.
'97 950 T-5 Wagon
RedBrickCollector wrote: 08 Jan 2024, 01:01 The issue I have in front is that the threads for the axle protrude past where the center cap would go by a good 8-10mm. It seems there have been similar issues reported on the forum and the cause was stated to be because there's two different axle mounting types, one using a bolt and one using a nut. I'm on the nut type which leaves me with a lot of thread protruding from the Thors. I'm contemplating just cutting the thread but might go for raised caps instead.
The bolt axle is used on the 1999 - models i North America, I don’t think you can interchange these as the wheel hubs are different , too.
Check?
