RedBrickCollector
Year and Model: 1997 850 T-5 Wagon
Has thanked: 40 times
Been thanked: 29 times
Post by RedBrickCollector »
scot850 wrote: 23 Jan 2024, 08:32 There is a cheap repair kit for repairing the tailgate mounts. Skandix probably sells it. Volvo sells one but they do not include the clips to remount the inner cover, the aftermarket one usually does.
The car came with one of those already installed, along with a fiberglass repair for the trim itself. Well, it had the repair kit on the two remaining and those were close to unusable too. The L shaped piece itself was pretty much gone, nowhere solid for those to mount to.
I believe the climate here is literally the worst case testing environment for plastics and electronics, the kind replicated artificially for part validation.
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
Has thanked: 2212 times
Been thanked: 1853 times
I understand what you mean. Maybe keep an eye out for another one in better shape. Even if it is the wrong color you could cut off the mounts and glue them to your original one.
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
RedBrickCollector wrote: 23 Jan 2024, 08:31
foggydogg wrote: 23 Jan 2024, 07:57 Those are the latches holding the seat cushions in the car. Unclipping them allows removing them completely.
Something might be broken on mine then, as they don't seem to have any effect, I can pull them out either up or down. Thanks.
Muck Of Ages. Squirt a bit of stuff like WD40. Or, if you don't need to get the bottoms out, let sleeping dogs lie.
RedBrickCollector
scot850 wrote: 23 Jan 2024, 19:07 I understand what you mean. Maybe keep an eye out for another one in better shape. Even if it is the wrong color you could cut off the mounts and glue them to your original one.
I bought one in better shape (externally it was in two pieces instead of 4), and the mounts are worse ironically. Unfortunately when I attempted to repair it, I ended up turning it also into 4 pieces. Now I'm using the one that had been already previously repaired, and if you aren't in the back or looking for it, it's alright. I'll still be looking to get a better one but there are other priorites for the car in the meantime.
'97 950 T-5 Wagon
RedBrickCollector
foggydogg wrote: 23 Jan 2024, 22:37 Muck Of Ages. Squirt a bit of stuff like WD40. Or, if you don't need to get the bottoms out, let sleeping dogs lie.
Other way around I think, but same conclusion. I can get them out, maybe they're a little too eager as they want to pop off when I pull the tab to fold them forward. Still, it's not an issue so I'll just let it be.
'97 950 T-5 Wagon
Post a picture of the clips on the seat. It may be they have been fitted in reverse.
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
Swapped out the starter on her GLT today.
It's been giving some solenoid trouble the past couple of weeks. Slow to engage, hanging up slightly, or just plain nothing until a couple taps with a hammer. Was very sporatic.
Had a good used one in the stash and got it swapped out pretty quickly.
Doing the fan "tuck" on it a while back made for MUCH more working room. Just needed to remove the upper IC tube and the air cleaner intake duct to get all of the room I needed to unbolt everything.
Has thanked: 1613 times
Been thanked: 4075 times
I replace the four fan lag screws with cheap stainless crap and leave the bottom two slip tight. That makes fan removal a 1 minute affair
Chuck W
Post by Chuck W »
Didn't even have to touch the fan. ;)
levalexi
Year and Model: 2000 v70 xc se
Has thanked: 9 times
Been thanked: 6 times
Post by levalexi »
Update on my 2000 V70XC no start
Still no crank
Bench tested the starter, it's fine.
Cycled the shifter to no effect
Swapped starter relays
Swapped starter and battery from my working v70
No significant voltage drop when turning the key
Starter is getting 12v
Tried jumping the starter with my switch
Tried to reset the immobilizer in case that was the issue.
Up next is replacing the Spade connector, but the voltage was fine iirc.
If that doesn't work (which I'm going to assume it won't) I'll finally be pulling the PNP switch out and rebuilding it.
My coworker with vida is coming over this week to see if I missed anything obvious and see if the computer brings anything up .
I'm at a loss as to how this happened. Being a 2 day difference between it running and not running.
