I recently was tempted to buy some LED headlight "bulbs" (high-beams) without fully knowing where I'd install them. The 850 makes the most sense, since that gets driven 50 miles a "day" in the very early morning hours, where I'm often alone on the highway.
They arrived today, and I started (trying) to install them. They're not exactly formed like a standard bulb base, but they seem to fit with some fiddling in a spare housing for my truck, so I moved on to the 850.
I got the passenger side in, and it lit up bright white, and I can't wait to try it tonight. However, I can't get the existing bulb out of the driver's side, and I noticed that it's clocked differently. I would have thought that both bulbs would be clocked the same way, and why can't I budge it? Any ideas? (good ideas?)
Also, the existing bulbs are Sylvania's..... I assumed they'd be Hella. Have then been replaced? I have not found much non-factory on this car.
Headlight bulb fitment
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 131 times
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- RickHaleParker
- Been thanked: 958 times
Put a drop of penetrating oil on it and let it soak in.
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
Had the same problem in a much older car many years ago. After the bulb broke, i used a set of expanding pliers to get the base out then was about to install a new bulb. If you dont have those pliers sometimes what works is to use the handle end of a screwdriver of the right size. Stick the handle in the base and turn. May have to play with it a little.454cid wrote: ↑28 Jun 2022, 12:52 I recently was tempted to buy some LED headlight "bulbs" (high-beams) without fully knowing where I'd install them. The 850 makes the most sense, since that gets driven 50 miles a "day" in the very early morning hours, where I'm often alone on the highway.
The trick to preventing this is to use what they call "bulb" grease. It's really silicone grease and it is a special kind of grease that does not harm plastics. It's the best grease i think for slow moving parts, but maybe fast moving too.
Grease is an insulator, but because the coating is very thin it does not stop conduction with normal voltage levels. It does prevent oxidation and thus stops the bulb base from getting stuck in the socket. Makes life a lot easier.
I dont buy bulb grease anymore i just buy the silicon grease from an auto parts store. I got one tube from Auto Zone and another pressurized cylinder from Amazon. As long as it is silicone grease it's good for this stuff and other plastic moving parts.
When i converted my Volvo lights i took out the bulbs and installed one unit in each side that did both high and low beams. IT wasnt easy though the wiring was a trick to get run right in that tight space.
454cid
Gah!!! Apparently I moved something while trying to install the passenger side bulb. I adjusted the aim, and lightly pushed on the back of the bulb when I got home, and something inside the housing let go. I must have had the thing right at the end of it's adjustment. Haven't searched yet..... how hard are these things to disassemble so I can put it back together?
MrAl, the silicone grease sounds like a great idea.... these bulbs have o-rings after all.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
454cid
I've got a spray dry-lube, I wonder if that would work. I really don't want to put oil in there. These LED bulbs may get returned. The one I did get in place seems to rock up and down.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
454cid
Looks like Robert covers it here, pretty well. I have the new lights, but I'd guess it's similar.
I wonder if I can possibly re-seat the reflector without disassembly.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 1506 times
- Been thanked: 3822 times
Take it out to reseat the reflector. It’s tough on car
Three M6 bolts, 10 mm hex head socket. Flex and gun are nice after they crack
- MrAl
Hi again,454cid wrote: ↑28 Jun 2022, 23:23 Gah!!! Apparently I moved something while trying to install the passenger side bulb. I adjusted the aim, and lightly pushed on the back of the bulb when I got home, and something inside the housing let go. I must have had the thing right at the end of it's adjustment. Haven't searched yet..... how hard are these things to disassemble so I can put it back together?
Yes it helps a lot and lasts a long time.
But i forgot to add one detail. They often sell this stuff as "Dielectric Grease" and that's the right kind. It's just clear silicone grease.
Good luck with it.
454cid
Messed with this some more yesterday. With a flashlight, I could just barely see the point of disconnection on for the reflector. I was able to reconnect it, but it doesn't stay well. This leads me to believe that it may be worn or cracked. It's a bit strange that I can't seem to get the same reading on the bubble level that the other headlight is adjusted to. I run out of adjustment. I did get it better..... I found my core support was not fully secure and tightened the bolt down just behind the corner light. It could be this is remnant from a collision, as I do see signs of bodywork (over spray).
I'm contemplating trying to get a used light, or set of lights, and maybe a set of e-code lenses. I've also thought about going aftermarket with TYC lights or Pro-Parts, but I'm a bit leery of that since other TYC headlights are known to not have reflectors with good optics. I could also just see if that connection holds, and not worry about it unless it doesn't.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
I’ve been happy with TYC headlights on two of the 1999s, FWIW
- 4555 Views
Last post by adrian22
- 3864 Views
Last post by silentcircuit
