MAF Question
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
azureblue
Year and Model: 2014 S60 T5
Has thanked: 16 times
Been thanked: 8 times
MAF Question
Post by azureblue »
I had the local car parts place run a scan and they reported no codes. I knew it was time to change the plugs and I did, going to the Bosch cross reference for the stock plat plugs. Is it possible for the MAF to not work properly and not throw a code?
I went looking for replacement MAF elements for my 2001 V70 T5, and found several numbers. I am not sure what is in the car now, is stock, so I am asking which element should be there? Much thanks
And if you have not thrown a few bucks at Robert Spinner, please do so....
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
Has thanked: 1509 times
Been thanked: 3827 times
Pretty much,no. If the MAF isn’t working right the mixture won’t be right, the OXS sensor will detect that, send the fuel trims out of range, and voila,you have codes.
The fuel trim has a working range of about 10-20% before it codes so a MAF ERROR larger than this will likewise code
I would leave it alone, no cleaning ,either
azureblue
Post by azureblue »
Thanks - saved me chasing my tail...
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 608 times
Post by vtl »
I drove my XC70 about 200 miles with MAF disconnected. The car triggered error only on the following start. I think, turbo engine relies more on MAP sensor (measures both air pressure and temperature after intercooler).
Also the fuel trims didn't move a hair, I monitor vital car sensors at all times via my "tiny VIDA": https://github.com/vtl/volvo-ddd
azureblue
Post by azureblue »
I'm interested in the Tiny VIDA. I followed the link but couldn't find where to buy / Download, etc
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 116 times
Post by xHeart »
azureblue wrote: 06 Jul 2022, 15:46 I had the local car parts place run a scan and they reported no codes. I knew it was time to change the plugs and I did, going to the Bosch cross reference for the stock plat plugs. Is it possible for the MAF to not work properly and not throw a code?
MAF is after the air filter, and first in air-fuel tango. Cleaning up airbox replacing air filter, and then spray cleaning with MAF cleaner can be steps before the next step.
With the age and mileage, the entire air intake (all pipes and sensors between airbox and throttle body) is up for an overhaul.
vtl
Post by vtl »
azureblue wrote: 08 Jul 2022, 09:51 I'm interested in the Tiny VIDA. I followed the link but couldn't find where to buy / Download, etc
It's more of DIY.
