What wheels fit my car?
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
AlanS
Been thanked: 2 times
Post by AlanS »
2006 XC70 Ocean Race 17" wheels. I am looking to replace them, as they have corroded and are unrepairable. Two wheel finishing shops said that they 'could do it, but the corrosion might return...and...the wheels are so damaged from the corrosion that the finish-if it lasted- would be uneven and show the damaged metal underneath. THAT SAID...I have been looking around for replacements...Aside from the 17", I see other numbers to consider- IE: 5x108 was on one of the sellers descriptions. Aside from pulling a wheel off my car and hoping that I could even find the id numbers, does anyone know the specs that I am looking for when replacing my original OR 17" wheels? Thanks, Alan
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1254 times
Post by matthew1 »
5x108 is a requirement, full stop.
Do you intend to use your current tires?
If so, 17 inch is a requirement, as is the width spec to fit those tires, full stop.
I'd press the Easy Button and buy used wheels of the same design from someone on Facebook Marketplace or Craigslist.
Member since 2006! Bravo! So far back that Location wasn't yet in user profiles :shock:
Also -> Amazon link
AlanS
Post by AlanS »
What is meant by Easy Button? What is the width of the XC OR wheel for comparison. I have looked at FB Marketplace and there are Volvo wheels, but not from my model or year. As said, the one set that looks promising says "17- 5x108 . Since the seller is from another state, I want to be assured of EXACT fit prior to purchase. And, yes...I will be using my current tires.
matthew1
Site Admin
Post by matthew1 »
Here are your wheel possibilities. The widths are listed below the image.
Volvo p2 wheels.jpg (230.61 KiB) Viewed 752 times
17 inch Volvo OREANDER alloy wheels.jpg (74.13 KiB) Viewed 752 times
The Easy Button just means doing something simply, without complication.
Also -> Amazon link
Has thanked: 1856 times
Been thanked: 1717 times
Assuming the wheels are Volvo originals, they have raised letters on the rear between the spokes. Yours will probably be 17 x 7.5 x 49
17" is diameter, 7.5" wide and 49mm offset. There is also usually the Volvo part number as well. As stated 108 x 5 wheel bolt spacing.
Not sure what tire size you are running but if you go to somewhere like TireRack.com they will have specs for you and options on sizing. The standard XC runs with 215/65/16 tires. So I will guess yours may be 215/55/17?
Has thanked: 1509 times
Been thanked: 3827 times
Alan..if Erie vovo in Utica has your wheels I could get them To you on the Albany to Long Island weekly fast train. I don’t come over by car every week but do on occasion.
