My 850 goings on ???
loveMy850
Year and Model: 1994 850 WAGON
Has thanked: 97 times
Been thanked: 4 times
Post by loveMy850 »
Hi Guys been awhile, I think I blew a head gasket. I'm lost bc absolutely no Volvo mechanic around here. Need a rebuild, or letting her go. I'll sell. 😥😢really tears me up, but I can't rebuild her, don't have the means tried everything but the timing. Could it be the timing?
Clemens
Has thanked: 473 times
Been thanked: 219 times
Post by Clemens »
If it is the head gasket, then you need to get that fixed. I don't think anything timing related would cause head gasket like symptoms
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
800artfreed
Year and Model: 98 S70T5; 99 S70GLt
Been thanked: 26 times
Post by 800artfreed »
What are the symptoms? Have you tried to test using the color change testing tube? If you suck air from the overflow bottle and the fluid changes color it indicated gas fumes leaking from the combustion chambers into the coolant system. This is an indication of a leaking head gasket.
test fluid kit.rtf
(3.33 MiB) Downloaded 52 times
VolvoVoyeur
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
