srs urgent message after sunroof leak in heavy rain
englandfoamily
- Year and Model: 2001 volvo v70
2001 volvo v70. Sunroof clogged and we got torrential rain. Opened car and the drivers footwell had standing water in it and the steering wheel was wet, some water on dash as headliner had leaked. Used towels to soak up water and dry everything. Snaked sunroof drain. After that I tried to turn the car on and everything went nuts and then turned off (previously just turned key enough to open sunroof). Opened fuse panel on drivers side and and it had water in it, not a ton but water droplets. Unhooked battery, used blow dryer to dry visible water drops and then ran a dehumidifier and fan blowing through dash for two days. Reconnected battery today and everything seemed fine. Car ran fine, no issues with instrument panel but now the "srs urgent service required" message is on the dash. Initially the sunroof wasn't working but did the lock and unlock doors three times reset trick and that is fine now. Is there a connection in that footwell that could have been damaged causing the sos urgent message? Fuses are all fine. Thanks in advance for any help
englandfoamily
Used code reader and no diagnostic codes come up. Just a regular code reader though, not VIDA.
motormikeyman
- Year and Model: 2004 XC70 AWD
- Been thanked: 8 times
You will need to reset the SRS warning using a Volvo compatible reader/tool like below. It cannot be reset any other way.
https://www.amazon.com/AUTOPHIX-ES610-S ... r=8-5&th=1
'94 940 wagon, 220K miles- sold to a guy who then drove it to Oklahoma
'99 XC70 AWD, 210K miles- trans went
'04 XC70 AWD, 196K miles- still going strong
'06 S40 sedan, 150K miles- went with the ex
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
sounds like the srs circuit was interrupted before the battery was disconnected.englandfoamily wrote: 17 Aug 2022, 10:31 Used code reader and no diagnostic codes come up. Just a regular code reader though, not VIDA.
might be a good time to get a vida set up on a laptop.
- 27 Replies
- 28330 Views
Last post by cn90
- 2255 Views
Last post by An R rated life
- 17 Replies
- 4379 Views
Last post by jimmy57
- 6349 Views
Last post by regent
- 1637 Views
