I replaced my 98 S70 rear pads years ago. Pretty easy. Now I'm near 70 and have the car up to do it and tempted to blow it off.
Is there a simple way to get the calipers to release so I can get the pads out (and new ones in).? Seems it's tougher than I remember.
Isn't there some sort of valve I can loosen? I need this to be easy or I'll just take it to a shop.
And do you grease the shims also? Both sides? -- thanks
Replacing '98 S70 rear brake pads
If you hit the bleeders with 28 seconds of propane heat they rarely break
mar601
- Year and Model: 1998
- Has thanked: 34 times
- Been thanked: 5 times
Can you actually get the pads in and out without touching the bleeder? Anyone know of a video somewhere that shows how to deal with the caliper pistons in replacing the pads? Trying to make this as easy as possible -- will have to do it myself because I can't get an appointment till Thursday.
You can push the pistons back in with a lever after you remove the old pads. Protect the face of the piston with something
- Has thanked: 2199 times
Remove the brake master cylinder cap or at least loosen it so it is just sitting on the top of the master cylinder bottle.
I have been able to carefully use a pry bar or long heavy duty flat blade screw driver to push between the pad at it's end where there is no material and the disc. If you are feeling a huge amount of resistance then it may be your rear calipers have rusted and frozen.
You can also try hitting the edge of the pad with a large punch or chisel so shock the pads loose as they can jam. I have also had success using a long punch down the inner side of the pad from the 'drum' for the parking brake to help push the pad out. Problem is if you have a large wear lip on the disks then you may not easily push or pull the pads out.
Large channel locks has have been suggest may work.
Good luck!
Good luck!
- 660 Views
- 2254 Views
Last post by fishingdad101
- 593 Views
Last post by SuperHerman
- 1748 Views
Last post by mkc1
- 14 Replies
- 3861 Views
Last post by instarx
