Well this is a bit odd -
Left turn dash indicator stopped working. But the signals themselves work. And the dash indicator does work with the hazards on, so the bulb is good. Normal clicking sound, but no green arrow. Any ideas ? Only thing I can think of would be the stem itself, but that seems weird to me since I hear the turn signal clicking.
Turn signal indicator issue Topic is solved
- Has thanked: 2200 times
Could be a bad earth connection either from the light unit itself or internal to it. Even a failing bulb can give the symptoms. Only other thing might be the flasher unit or relay.
Definitely up there in the weird dept.!
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Under the dash, to the left of the steering column,
you'll find two large distribution blocks with 5 plugs each.
The one nearest the column has a red plug in position 4.
Disconnect the negative post of the battery, then unplug
and reseat the red plug a few times. That may get it.
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
Well you nailed it BEJinFbk ! I did exactly as you suggested and bingo - The indicator works again.BEJinFbk wrote: 23 Aug 2022, 21:41 Under the dash, to the left of the steering column,
Thanks again !
1999 V70 GLT
1999 V70 GLT
- Sveedy
And now the radio doesn't work. I think I might have released an electrical gremlin....
1999 V70 GLT
1999 V70 GLT
- BEJinFbk
Without getting back into the diagrams,
( on the wrong device right now...) I can’t
recall if any radio power runs through that
particular power distribution connector or not,
but it can’t hurt to be sure that it’s well seated.
Did this car ever suffer any flood damage?
Plays heck with connectors...
- Sveedy
No flood damage here. I'm the second owner, and I don't think the car has even been driven in the rain more than a dozen times in it's life.
But the original owner lived in an area that loved speed bumps. Everything rattled when I got it, so who knows what might be working loose.
I figure that it has to be a connection under there. Antenna doesn't rise either.
1999 V70 GLT
1999 V70 GLT
- 1718 Views
- 1546 Views
Last post by volvolugnut
- 3424 Views
Last post by 93SCMax
- 1365 Views
Last post by Dezz
- 653 Views
Last post by ljsommar1
