Well, the worst has come - head gasket or cracked sleeve
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
After noticing coolant that wants to rush out of the tank + upper hose being expanded and firm to the touch, I decided to do a block test - results are exhaust gasses in coolant tank.
The engine is a non-turbo 2.4i 140hp variant auto. What are the chances this is just a head gasket and not a cracked cylinder like the R series?
I also had low-er compression on cylinders 1,2,3 as follows:
cyl 1 - 180psi
cyl 2 - 160 psi
cyl 3 - 160psi(or thereabout, could be 170 I kind of forgot but between 160 and 170)
cyl 4 - the strongest champ at 210 psi - this is healthy
cyl 5 - 205 psi - still healthy.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
I say gasket.
Because its cheaper.
Has thanked: 1609 times
Been thanked: 4064 times
Gasket. These blocks don’t crack.
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
dikidera wrote: 23 Aug 2022, 09:13 I also had low-er compression on cylinders 1,2,3 as follows:
cyl 1 - 180psi
cyl 2 - 160 psi
But not half, and not zero. I agree with these guys above.
Has thanked: 2197 times
Been thanked: 1850 times
Actually they do crack. I was going to look at a 06 XC90 2.5T but was asked by the Volvo dealer in Edmonton to delay as they had found an issue with the car during inspection. Turned out it was a cracked block at the back.
They ended up putting in a higher mileage engine and then wanted me to buy it at the same price! Walked away quickly.................!
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Take it apart and have a look. Guessing doesn’t lead anywhere.
BMW 540i 2002
S70 Base 2000
Agreed. If you have access to a boroscope you could pull the lugs and take a look at the bores for any signs of damage.
dikidera
Post by dikidera »
I'll have it at a shop soon, just need to take care of a few matters. But most shops told me the same story - not unlikely to have cracked the block and not the head gasket. And then sourcing a new engine means risking buying it with the same damage.
BlackBart
Post by BlackBart »
I don’t see the cracked block unless it froze with the wrong coolant mix in it.
What else would cause that?
jonesg
Post by jonesg »
BlackBart wrote: 26 Aug 2022, 07:41 I don’t see the cracked block unless it froze with the wrong coolant mix in it.
theres an inherent weakness between middle cylinders, more common with R variants.
