13g to 16t swap
Petskoi
Year and Model: 1997 V70 awd
Post by Petskoi »
So I have the 13g with a straight housing(if its the right word) and I have a 16t with an angled housing. What volvo model downpipe do I need to buy to make it work? In my understanding I should buy like a -99 t5 downpipe right? Or is it an easy job to modify the stock dp to work?
Otherwise the swap should be just bolt on with the same lines?
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 276 times
Been thanked: 84 times
Post by hausmeister »
Angled DP would be the easiest and best option I think. If you are getting a new one anyways and already have the angled turbo.
850 T5-R '95 auto Image
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
Not a lot of options with this. I wouldn't waste money on anything with the straight exhaust flange. As hausmeister says, you already have the angle set-up, so I'm sure you're going with that. I just went through this a little bit ago, but with a 15g. You used to be able to buy just a downpipe alone from OBX but I couldn't find a source for them anymore. Then there are a couple of way expensive turbo back exhaust systems out there. I ended up having to bite the bullet and buy an IPD system which came with a 3" angled downpipe. Unfortunately I think they just had a price increase on their system.
1999 V70 GLT
Petskoi
Post by Petskoi »
Thanks for your replies, otherwise I could just buy a dp but as I have the awd and all the downpipes I can find are for the fwd, I have to play welder
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Post by Goupil »
TME (sweden) makes an AWD downpipe, it's good stuff but it aint cheap
http://www.tme.se/e_index.htm
Wasnt able to find an european shop with a listing
https://www.vivaperformance.com/tme-per ... 1999-2000/
A stock angled downpipe would be the 2nd best solution.
The 16T should bolt fine, if it's from a 99+ you might have to play with the coolant ports plug (-98 have IN on the engine side, OUT on the firewall while 99+ have both on the firewall side. Any turbo should have 3 ports with one plugged)
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
gizmaster_1
Year and Model: 850 Turbo 1995
Has thanked: 5 times
Been thanked: 3 times
Post by gizmaster_1 »
Hi there, I came across this post so I thought I would try my luck
I'm thinking of swapping my factory 13g turbo to a 16T and I have a few questions.
1. Can I just buy a 16T compressor/housing and use it on the factory turbo? Will it give me the same improvement as installing a complete 16T?
2. Can I do a straight swap or will modifications be needed?
3. I bought the IPD Boost Control valve but didn't notice any difference, is a special set up required?
4. Should I get a manual boost control valve?
Thank you in advance
Luis
Sveedy
Post by Sveedy »
1. I don't really understand this question. Are you asking about switching the internals of the turbo ? In any case, what you want is a complete 16T. Keep in mind that you need to have a different tune in the ECU for you to notice any difference between the two turbos.
2. They bolt up the same way, so no mods required.
3. I have heard nothing but bad regarding the IPD boost control valve. Pierburg is a better choice. Might be originally for a Porsche.
Not sure, so check, but #99660 or # 515500 is in my notes.
4. If you like. There is a link here on the site on how to make one.
1999 V70 GLT
V50M66
Year and Model: 1998 V70 AWD
Has thanked: 26 times
Been thanked: 94 times
Post by V50M66 »
gizmaster_1 wrote: 26 Feb 2024, 16:15 Hi there, I came across this post so I thought I would try my luck
Luis
Did it myself a few months back.
1. Absolutely not
2. Make sure it is a -01 16T and it should bolt on fine (except exhaust, which needs an angle flange downpipe. If FWD, get the OBX system off eBay. If AWD, you're SOL and should find a 15G instead so it'll bolt on unless you're really handy with a welder, since nobody makes AWD downpipes)
3. IPD boost valve is absolute trash, get rid of it and put the stock one back.
4. No, you shouldn't. You'll break something in short order
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
gizmaster_1
Thank you so much for the info. I believe my car is a straight flange not an able one, can I still use the 16T turbo with a straight flange?
Sveedy
Post by Sveedy »
My understanding is that you can use the straight flange, but the angled has better flow.
And I believe Vast Tuning also sells downpipes.
1999 V70 GLT
