05 s60R 5spd-auto Belt quealing noise, but it's not the belt. Video included.
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
renegade420
Year and Model: 2006 s60r
Been thanked: 3 times
Post by renegade420 »
I have developed a squeeling noise that everybody who listens to it (including myself at first) thinks it the serp belt as any normal person would. Symptoms are also very similair to that of a serp belt in which the noise really only happens when the car is either in D or R and also when in D, I can turn the wheel and the noise will stop for a sec or 2 or sometime completely if i hold the steering still at just the right angle. So, i got a new serp belt, and while belt was off, spun each pulley by hand, heard nothing, installed the new belt but the noise continues. And, when listening to it again, the sound actually almost sounds like it might be coming back by the turbo area. Any ideas??
New video.mp4
(6.14 MiB) Downloaded 124 times
Video attached.
And i might add, it seemed to have started shortly after my AC line was busted and leaked all the freon out (and now i have no AC :cry: )
dikidera
Year and Model: S60 2005
Has thanked: 67 times
Been thanked: 175 times
Post by dikidera »
I would imagine just because you spun each pulley, doesn't mean anything when you can't spin fast enough, but most importantly, there is tension on the belt when on, which would apply some force on the pulley, probably enough for the noise to come on.
renegade420
dikidera wrote: 04 Sep 2022, 00:37 I would imagine just because you spun each pulley, doesn't mean anything when you can't spin fast enough, but most importantly, there is tension on the belt when on, which would apply some force on the pulley, probably enough for the noise to come on.
So its probably the AC pulley since there is no freon?
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
renegade420 wrote: 04 Sep 2022, 07:06
try a long stethoscope or spray the pulleys with water.
