did i get a good deal?
SirBrickWagon
Year and Model: 1997 Volvo 850
Has thanked: 7 times
Been thanked: 11 times
Post by SirBrickWagon »
hey guys i'm back again!! no new problems with shit car as of late. just honestly curious if i got a good deal on him!
shit car is a 1997 855 with the NA 5cyl. he is dark green/blue-ish in color and has had his tailgate replaced after a vandal broke the glass. the tailgate is orange-red. shit car leaks oil everywhere but seems to magically regenerate oil as the dipstick will sometimes tell me the oil level is in between full and low. other times it will be at full. my mum does not like shit car leaking oil. shit car smells weird inside due to being smoked and vaped in by previous owners. shit car came with mismatched steelies with tires made only of hopes and dreams. shit car also had a bad exhaust leak caused by a blown flex joint at the headers.
so. that's all about shit car.
initial offer - 600$CAD
after negotiations - 500$CAD
(much more money has been put into this car)
1997 Volvo 850 Wagon (Non-Turbo) with too many problems to count
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Engines that seem to produce oil may have internal leaks of fuel, coolant or other fluids diluting the engine oil. Check for strange color of oil and foaming. These other fluids do not make good engine lubricants.
SirBrickWagon
could the higher oil level also be caused by a blocked PCV and checking when the car's been taken out for a drive?
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
Maybe, although I doubt it.
1996 855 R,
2010 V70 D5,
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
SirBrickWagon wrote: 09 Sep 2022, 14:43 could the higher oil level also be caused by a blocked PCV and checking when the car's been taken out for a drive?
For accurate readings....always check the dipstick level when the car sits overnight(cold engine),on a level surface and before starting the engine.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
SirBrickWagon
misha wrote: 09 Sep 2022, 15:33
whenever i take it out for a drive it's always sitting at a nice comfortable level. i think it could be caused by excessive pressure and checking when the engine's hot
800artfreed
Year and Model: 98 S70T5; 99 S70GLt
Been thanked: 26 times
Post by 800artfreed »
The usual test for blocked PCV system is pulling the dipstick and looking for smoke/vapor coming out. The follow up test is to take a plastic glove and put it over the open oil filler neck at the top of the valve cover. HOLD it TIGHT and seal it with your left hand while rotating the throttle cable sheave to increase the RPM a little. If the glove tries to get sucked in the PCV system is working. If it starts to inflate the PCV system is clogged. This can blow out your Rear Main Seal and the cam shaft seals. Fix the PCV system as soon as possible.
Another check is to use a chemical test kit for leaking hydrocarbons into the coolant system. This should be less than $50.00 US. Check it out on Youtube. The fluid changes color if there is exhaust gas leaking into the cooling system.
leak test.png (25.35 KiB) Viewed 472 times
VolvoVoyeur
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
SirBrickWagon
800artfreed wrote: 12 Sep 2022, 14:36 The usual test for blocked PCV system is pulling the dipstick and looking for smoke/vapor coming out. The follow up test is to take a plastic glove and put it over the open oil filler neck at the top of the valve cover. HOLD it TIGHT and seal it with your left hand while rotating the throttle cable sheave to increase the RPM a little. If the glove tries to get sucked in the PCV system is working. If it starts to inflate the PCV system is clogged. This can blow out your Rear Main Seal and the cam shaft seals. Fix the PCV system as soon as possible.
i've already done the test, the pcv's blocked and a new one's already on the way from IPD
